Old 03-14-2011, 08:50 AM
TunaMeltdown TunaMeltdown is offline
Default Deck Drain Frustrations!
Well After reading alot of archived material here going as far back as the sites begining I thought I knew all I needed to know about replacing the rear deck drains and the forward fish box thruhull in my 23' inboard. I was wrong. I ordered 170 dollars worth of moeller drain tubes, flanging tool, groco thru hull, and plenty of 5200 and started the demo process. Everything came out pretty well but thats about as far as I got. I bought 1" drain tubes because that is the original size that the boat came with (I think?) and someone in the boats 34 years of age hogged the holes to 1.25" . So my 1" drains will not work. Ok no problem I continue to the fish box drain, remove the plastic thru hull, dry fit the new brass groco, cut it to length and slather it in 5200 and put it in place. I tightened it from inside and jumped out to see how it looked on the outside and it was not seeted flush against the hull. Now I'm started to get really mad. The drain is located close to one of the chines and the mushroom on the thru hull is just to big. It seems to fit fine when you hold it in place but as you tighten the nut it will not seat properly? I'm kind of at my whits end here. I thought these would be simple replace ments and it seems I may have bit off more than I can chew. Any recommendations?
Thanks,
Dan Stewart.
1976 23' SeaCraft Inboard
Old 03-14-2011, 09:45 AM
Squido Squido is offline
Default Re: Deck Drain Frustrations!
Hey Dan I did this project last year. PIA!!!! for sure. I got stainless deck drains and remolded things with azek. The drains I got from marine connection liquidators in Fort Pierce Fla. They had everything for the job under 1 roof. If you want shoot me a pm with email and I will shoot some photos of what I did.
Old 03-14-2011, 10:13 AM
Thanks, I just spoke with Jamestown Distributers. Thats where I got all the stuff and they have 1.25" diameter x 3 7/8" long Moeller tubes that I am going to try.
Old 03-14-2011, 07:51 PM
Not sure if this helps but.....I replaced brass drain tubes on my Whaler years ago. Brass tubing from McMaster Carr. The ends to be flanged have to be annealed first. They form easy after this. Heat cherry red with torch and immediately quench in water. This keeps them from splitting. Form one end in shop. Insert and cut XXX (3/16"-1/4") longer then anneal. Insert in boat and form flange. The tool works ok, 2 guys w/hammer and tow ball work better.
Old 03-15-2011, 03:12 PM
After giving it much thought and wanting the most permenant fix in the long run I have decided to completely fill in the 1.25" existing drain area with West systems. I am going to sand down the fiberglass a little bit on both the hull and deck and glass in a small patch thus bonding the epoxy plug to the glass on the deck and the hull. When dry I will drill new 1" holes and procede to install the moeller drain tubes I had bought.
Old 03-15-2011, 03:17 PM
That sounds about like the easiest fix to me. I did the same on a 23 I redid and ended up just letting it drain in the bilge though.
Old 03-15-2011, 04:01 PM
You've probably already considered this stuff but just a heads up - the blocks of wood that support and surround the tubes will probably be pretty porous if not rotting as that's where any water coming in seeped first. When you do your fill, much of the epoxy may seep into and through the blocks and accumulate along the stringer. It might help to wrap that block first with tape or a layer of thickened epoxy. Stick a little rolled up fiberglass cloth in the holes before filling to keep the epoxy from getting too hot too fast. And also so consider getting a good angle measurement so you have that when re-drilling or the flare will not seat well in the bottom side...
Been there, done that
Old 03-16-2011, 12:42 AM
That's a good idea! I had exactly that problem on port side. Maybe if you wet out the cloth with epoxy first, and then roll it up on a pencil, you can stick it up in the hole and let it kick off before you fill the hole. You can also use a center plug from the bottom like I did to create a pilot hole to help keep the angle close to original. (You'll have to go to the end of that post that I linked to in order to see the photo of the plug.)
Old 03-16-2011, 08:27 AM
Meltdown,
Like Gilly said...thicken your epoxy a little and dry that block! And post up some pix
1974 23SF
Old 03-18-2011, 09:29 AM
Ok here it is so far. I got out of work early yesterday so I could get the tubes filled in, with the hopes I could drill them out this weekend and install the new moeller drains. This was my first time ever using west systems and doing any kind of fiberglass work Thank god for first grade paper mache class. Any how I tried to use duct tape to seal the bottom of the holes and fill the tube with thickend epoxy. WRONG. It only took about 2 minutes for the duct tape to fail and my epoxy to be all over the lawn. Then I took 2 small squares of fiberglass and slathered them in epoxy and let them get tacky and then stuck them in place and let them dry. (Thanks John) I let them dry in place over night and this morning they were hard as a rock. So quickly before work at 6am, I mixed up a really thick batch of epoxy and poured it down in the tubes and then placed another small fiberglass patch on the top to tie it in with the deck.
I was working by myself so I was only able to snap one picture.
[image][/image]
