Old 03-20-2011, 11:25 PM
ElBichoMalo ElBichoMalo is offline
Default Bedding Compound? Sealant? Which Fittings?
I am a little confused about which pieces should be installed in a "bedding compound," which should be caulked in with sealant, and which don't need either. Also, what exactly should be used for "bedding?"
cleats (pull-up style): bedding?
bow light (pull-up style): bedding?
thruhulls: sealant (4200)
rodholders: bedding? gasket?
fuel fill: bedding?
louver vents: nothing?
misc. rails, ss/alum accessories: nothing? bedding?
hinges/pulls on hatches: bedding? nothing?
everything else???
I'm sure a lot of it probably doesn't matter, but would love to know the right way to do it, or least what the guys with more experience think...Thanks.
Old 03-21-2011, 09:02 AM
aldo aldo is offline
Default Re: Bedding Compound? Sealant? Which Fittings?
On my boat anything below the water line gets Life-Caulk,
any thing above gets Life-Seal.
Any time you put a fastener through fiberglass there is an opening for water intrusion.
Good luck with your project.
Old 03-21-2011, 09:32 AM
pelican pelican is offline
sealing the core,as certain equipment is installed is a very important step,most owners skip-rod holders installed in the cover boards,these are an excellent example-the hole for the holder goes through a cored surface-the cored surface,be it either wood,or composite,needs to be properly sealed,to prevent water intrusion-polyester based resin,is a poor choice for this-epoxy ,being waterproof,is a much better choice...
as for me,deck hardware,thruhulls,etc,3m 5200-there's a common mistake made by the inexperienced,3m 5200 is permanent,untrue ! over the years,i've installed numerous equipment on customer's boats,bedded in 3m 5200-in the case of a few,the equipment was removed,without damage to both the boat,and the equipment.i've removed many transducers,bedded in 3m 5200,gunnel caps,rod holders,etc...
here's some more information on this very subject,it's one of my facebook pages...
http://www.facebook.com/?sk=lf#!/pag...ce/71018074689
Old 03-21-2011, 10:11 AM
This might help you !
Old 03-21-2011, 11:47 PM
Island trader... you hit the nail on the head...that is pretty simple to follow...thanks.
