Old 03-24-2011, 09:54 PM
bbh57 bbh57 is offline
Default Electric sander
I saw one of these sanders at Fiberglass coatings today. powerful and lightweight 1.9 lbs! Very nice. But a bit pricey,
http://www.abglovesandabrasives.com/servlet/the-433/Mirka-CEROS-550CV-5"/Detail
Old 03-24-2011, 10:16 PM
Default Re: Electric sander
http://www.abglovesandabrasives.com/...50CV-5"/Detail
Yo Bill,
Waz-up with the link???
How long you been at this??
I know you can do better!!!
See ya, Ken
Old 03-24-2011, 10:22 PM
Sorry guys dont know why its not working
the sander is a Mirka CEROS
Link works only when you copy and paste in the address bar, Dont know why?
Old 03-25-2011, 06:17 AM
thegoggleeye thegoggleeye is offline
ive done enough work with d/a's (orbital sanders) to build noah's ark out of a tree and i can tell you there is no rational for spending that kind of money on a sander unless your hourly rate will cover the price in one hour. for light weight sanding stick to a pnumatic sander. dont waste the money. a $60 porter cable d/a will do everything u need (except walk ur dog)
mechanical engineers build bombs. structural engineers build targets.
Old 03-25-2011, 09:10 AM
I agree goggle. I have the proter cable and it has been doing all I need it to. It has a 5" sticky back. The only reason I did the sticky was someone gave me a bunch of 5" 80 grit sticky pads. I have a pnuematic kobalt 6" with hook and loop pad that is a good sander too. Used it on my 23' and it still has plenty of life left. It was like a $50 sander too.
Old 03-25-2011, 11:14 AM
KenB KenB is offline
I got some cheap refurb rigid sanders. 5 inch orbital and 18 inch belt together were under $80. Both fit with the rigid vacuum I already have.
One trick I figured out is to take a bungie cord and hook both sides over the gunnel. Then put the sander in the loop. Now you just have to move the sander around, bouncing on bungie, instead of holding it up the whole time.
I have long and short bungies, which seems to be enough (connect them end to end) to cover most the sides and bottom.
