Old 04-10-2011, 11:42 PM
Wags23 Wags23 is offline
Default engine on center stringer
Have a new vw diesel.Problem is the oilpan hits the center stringer and its an inch and a half too high.Engines an i/o.
Is the center stringer structural? Could i raise the transom assembly 2 inches?
Old 04-11-2011, 12:21 AM
Default Re: engine on center stringer
I dont see how it would hurt anything. Maybe cut it down enough and lay a couple layers of glass on the bottom and also to the sides of the stringer.
Old 04-11-2011, 08:13 AM
Cut down the stringer enough to give you at least 2" clearance, then close/rebox the open top of the stringer with some heavy mat.
Old 04-11-2011, 08:44 AM
with the motor sitting in there will it align with the out drive or do you need to raise that as well?
1979 Septer I/O no power Sold
Old 04-11-2011, 11:01 AM
engine is 10.4 inches from datum point to bottom of oilpan. I only have 9.5 inches from gimble bearing to center stringer.So I can't align (wont sit on rear mounts)unless I cut stringer(engine will be low in the bilge err) or move the transomm assembly up.
Old 04-11-2011, 12:38 PM
If you move the transom assembly up, you also elevate the ventilation/cavitation plate on the lower unit. You need to check that data, too, to make sure you won't ventilate the prop in rough water or in turns should you go that route. Sometimes raising the transom group just won't work.
Old 04-11-2011, 01:04 PM
Thanks Father Frank. I'm going to need someone to go over the boat and come up with the best solution.Anyone in mass want to make a few bucks?
Old 04-11-2011, 02:59 PM
aldo aldo is offline
I wonder if the oil pan can be modified?
I know they do it for race cars, and they do offer aluminum pans as an option on most marine engines. Just a thought.
Old 04-11-2011, 03:04 PM
A dry sump system would be overkill wouldn't it ?
Old 04-11-2011, 08:10 PM
Ya think?
