Old 04-12-2011, 11:18 PM
Default Poly tanks under center console in 20' MA
Seems like a logical thing to do if you don't plan on using the crapper. Looks like I could get 40 gallons up there. Put a couple of vents in the side by the rod holders and offset these outboards that no longer weigh 240lbs.
I figured I'd fill the existing tank space with buoyancy foam.
Anyone try this?
Old 04-13-2011, 01:27 AM
Default Re: Poly tanks under center console in 20' MA
I ended up putting a 50gal poly from INCA. Moved it three feet forward.
Old 04-13-2011, 08:45 AM
Thanks for the reply. You are still doing the rehab of our Master Angler, right? I want to hear how that works for balance.
Old 04-13-2011, 12:01 PM
If you need any help just let me know. I should be floating mine in a couple weeks so I will let you know. Finishing up sanding the primer today and mount the bracket tomorrow and start painting the weekend.
Old 04-14-2011, 08:38 AM
Will do, thanks!
