Old 04-24-2011, 08:19 PM
cwynne cwynne is offline
Default Looking for dash board parts
I just got my boat repowered with an e-Tec. The dealer has put a large 3.5 inch i command guage. It also had two smaller guages from the old motor. He has removed them and now there a hole. I am looking for a place that sells rubber plugs to fill the holes.
Old 04-24-2011, 10:57 PM
BigLew BigLew is offline
Default Re: Looking for dash board parts
Find a friend with a wood lathe and have him turn you a couple of plugs of mahogany or teak. It will look better!
Plan accordingly!
Old 04-25-2011, 12:01 AM
Hopefully you got the digital gauge. I started out with the "Classic" analog style, but after two tach's and one spedo died I switched over to digital style. They're uglier and much harder to read, but they work well and provide more info.
Why not just ask dealer for the old gages back if you just want to plug the holes?! Or you can get 2" gauges for the I-Command system, from either BRP or Lowrance, that would also fill those holes. I was surprised to learn that there are some parameters that cannot be displayed on the big gauge. Not at home now or I would check to be sure, but I believe engine trim position and Throttle Position Sensor readings can only be seen on the small gauges. I have 2 large and 2 small gauges and use them all.
BTW, as a new E-Tec owner, you should check out this great "CSC quality" owners group web site if you haven't already seen it! Lots of good info there from some very knowledgeable techs! Denny
