Old 05-10-2011, 07:21 PM
2182 2182 is offline
Default motor issues, carbs dirty maybe?
so i repowered a few years ago w/ a carbed 150 johnson on my 18 seacraft. had an old mercury 200 racing motor that ran like a scalded dog, but not very often. anyway, went out monday to go catch some breeder reds. ran ten miles, fished for a few hours, and on the way in i started losing power. motor bogged down at about 4000 rpm and would slowly lose power (bucking). i stopped, put it in neutral, let it idle for a few, and started again. got 1/4 mile or so, same deal. repeat, but just barely got her on plane, and went a bit farther before it happened again. this time was accompanied by loud warning beep and "check engine light", which means fuel flow restriction. this happened once before last time i was out (the previous monday), but just once, and i forgot about it. i change plugs and fuel/water separators every six months, but i think it may be time to clean the carbs. is that what this sounds like? would love to tackle it myself, but would love to get some insight first. im no master mechanic, but i can turn a wrench and dont mind getting dirty.
as for gas, i try to run ethanol free, but dont always. use bright blue startron religiously though...
Old 05-10-2011, 10:40 PM
Daltonmarineinc Daltonmarineinc is offline
Default Re: motor issues, carbs dirty maybe?
before going after carbsi would try and run it on a differnt fuel tank. this will sperate the problem,boat or motor. if it runs fine then try finding your fuel pick up in the tank.alot of times theres a screen that gets cloged up at the bottom.also check and see if there is a check valve at the tank its self. if it is the motor then yes, i would take the carbs off and clean them. make sure and buy kits before taking them off.the oring and gaskets will swell and will never go back together. good luck!
Old 05-10-2011, 10:51 PM
BigLew BigLew is offline
I'll bet you have water accummulation in the float bowls. take them off and dump them and clean them out. It is probably from water seperation from the gas and it has taken up most of the volume of the bowls, thus limiting the amount of burnable fuel reaching the motor.
Just my 2C. Good luck.
Plan accordingly!
Old 05-10-2011, 11:10 PM
fredetzel fredetzel is offline
check the anti-siphon valve I had the same problem a few years back and found some trash in the anti-siphon valve it is mounted to the top rear end of the tank where the fuel line connects to the tank. Also check all fuel filters and check fuel lines to make sure the new ethanol gas hasn't struck again.
1978 sceptre inboard fwc marine power
Old 05-10-2011, 11:46 PM
pulled apart one of the carbs pre-knowledge tonight (very carefully). they were clean as a whistle. factory clean looking. cleaned it anyway, then pulled brass screws in stack and sprayed cleaner in there too. checked fuel filter on front of fuel pump and that is clean too. i have already checked fuel pick up and the anti syphon valve has already been removed. im at a loss. might be another bad vacuum switch, i heard they made a bad batch from my mechanic, maybe the good folks at omc were kind enough to send me a bunk replacement the first time. not sure how that explains the loss of power, although it would explain the godawful beeping. i have an inline filter for fuel management (which i dont use) that i may remove and see if that does it. blew off work to catch fish monday, and now im paying for it w/ a crazy week. going to try and water test thursday maybe, any more insight prior to that would be much appreciated.
Old 05-11-2011, 08:41 AM
Hmmmm, maybe overheating?
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 05-11-2011, 12:02 PM
Yz2009 Yz2009 is offline
If you got a continuous warning tone and not beeping it could be the overheat alarm. Have you changed your water pump recently?
Old 05-11-2011, 12:55 PM
Definitely sounds like fuel starvation. When you let it idle for a few minutes, the pump refilled the float bowls, so you were able to get on plane until the fuel level in the bowls dropped. Hope you're not running premix (oil in the gas) instead of oil injection, because when you starve a pre-mix motor of gas, you're also starving it of oil! Have you checked the fuel lines between the pump and carbs? I had one of those lines deteriorate and plug one time on my old V-4. Could also be a weak fuel pump or a leak in the line to the crankcase that feeds the pulsations that drive the fuel pump!
Old 05-11-2011, 07:10 PM
this does make the most sense (starving the motor). i checked all the fuel lines from the pick up back last fall (when i replaced vacuum switch), all was good. at that point i replaced primer ball. i always check the fuel in the separator when i change it. this time had some lovely metal flakes, but no water. guess i will recheck fuel lines, add splice in place of fuel management filter, and try to water test. if that fails, motor is still under warranty, and she goes to the shop. the joy of living on the coast is this time of year there is a 2 week wait minimum at all mechanics, even the country guy i use in the middle of nowhere...thanks as usual for all your ideas and suggestions, ill keep you posted.
Old 05-11-2011, 08:12 PM
Year and model of Motah?
The check engine light/horn monitors vacuum for fuel. Get a good long sweep gauge with 20"s max and work your way back to the tank. I had a clogged Racor with maybe 30 hours on it after we got e 10 shoved down our throats. Cleaned out all the crap from my 20 yr. old tank.
I blew the VRO diaphram on my `96 150 last Tues. The kit was 62 clams and took about an hour. Very easy! I run premix.
Cheers,
GFS
