Old 05-30-2011, 08:56 PM
abl1111 abl1111 is offline
Default Mooring welding ?
A mooring that I use has worn through at the eye to where it can't be used.
Other than that - mooring is in great shape.
Can and how can a new eye be welded on ?
Old 05-30-2011, 09:12 PM
Bryan A. Bryan A. is offline
Default Re: Mooring welding ?
I have done something like this before, worked well.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 05-31-2011, 09:28 PM
Wildman Wildman is offline
I have welded a big Eyebolt shackle on the end in replacement of the ring. FYI: you CANT weld the mushroom back onto the shaft as it is pig iron, dont even bother trying.
http://www.trademe.co.nz/Business-fa...-372083614.htm
Old 05-31-2011, 09:58 PM
Thanks - I will look into the options. If a welder does it cheaply enough - I'll go that route - if not, I think I can pick up a new 75lb mooring for $75 ...
