Old 06-02-2011, 11:25 PM
bgreene bgreene is offline
Default Let's really talk SeaCraft ride characteristics !!
Tell me about the reality - do the older SeaCraft 23' CC's, Septre's, etc really ride much better than other " typical boats" in the same size ?
Do these hulls pound, or tend to list / flop over onto one side of the V and require constant trim tab adjustment ? Are they " bad" or good in a beam or following sea?
What's the real deal. I'm a salt water man, with lots of conditions in the 2' - 5' chop range and have had a few boats, just not a SeaCraft. If you're experienced, tell me about it.
Appreciated.
Old 06-03-2011, 01:19 AM
Default Re: Let's really talk SeaCraft ride characteristics !!
No they will not pound ever - design
aim them into anything and go - sometimes its better to go faster actually - depends on wave length
1/4 are a bitch for everybody and it will pound you - tack like a sailboat - go into it then adjust
Yes they are all of what you have heard - ever read an internet thread that didn't have somebody or multiple that owned one and said they wished they never got rid of it
Sceptre's will tend to be a bit harder but not that much, just since your further forward - loved mine. My fav
Old 06-03-2011, 01:23 AM
Power Boat Reports, an ad-free "Consumer Reports"-type magazine that's no longer published, tested a 23 a few years back. They said it was the softest riding deep V of that size they'd ever tested! Hard to explain the SeaCraft ride if you've never experienced it, but here's a shot at explaining the theory behind the hull design. The relatively flat outer panels, which create lots of lift and eliminate the need for lifting strakes, make it more stable than constant deadrise hulls. The vertical steps between panels trap air, which reduces drag and cushions the ride. (The shot of my boat below shows the aeration created by the water flowing off the steps.) The lack of lifting strakes also means there are no flat surfaces to slap and pound. However, the 23 was designed by Bill Potter, a rank amateur compared to Carl Moesly, who founded SeaCraft, invented the Variable Deadrise hull, and started building boats when he was a teenager! (Check out the Moesly SeaCraft web site for a good overview of SeaCraft's evolution and early history.) The geometry of the panels on the 23 is different from all the Moesly designs, so I don't believe Potter really understood the principles of the VDH design. As good as the 23 is, I believe the Moesly 21 rides even better! I base this on my own experience as well as the following story from the Moesly SeaCraft site:
Moesly and some other builders with race-boat experience built some deep-V boats for the government in the early 60's that had to carry a certain payload with a specified engine/outdrive. They had a "shoot-out" on Biscayne Bay, and his 21 was the only one of the bunch that could get on plane with the specified load and power! In an attempt to "help" his competitors, he had them offload some people and sandbags to his boat, but they still couldn't get on plane. He then proceeded to try his boat with the extra load, and it still got on plane with no problems. Needless to say, he won the contract! Moesly claimed that his hull design, for the same deadrise, weight and power, was about 10% faster than the other conventional Ray Hunt type deep-V's of the time, which would have included the likes of Bertram, Formula, Donzi, etc.
A good friend of mine who is an avid diver bought a new 21 in 1965, used it almost every weekend for over 25 years, and made several trips to the Bahamas every year. A lot of 23's made that crossing with him, and he said that every time the seas got over about 3', the guys with the 23's would get on the radio "begging for mercy", asking him to slow down! (He didn't run that fast, typically cruising at about 20 kts.) I made 6 crossings with him in my boat, and after following him for about 2000 miles around the Bahamas as well as riding in that boat, I believe that story!
Suggest you contact a CSC member close to you and see if you can bum a ride sometime when the seas are appropriately lumpy! A ride in those conditions will speak much louder and more convincingly than any amount of talk!
Old 06-03-2011, 03:10 AM
BA17 BA17 is offline
The only complaint I have with my 23 is that it will hit "hard" if you don't have the weight centered. If you go over a wave with too much weight on one side the boat will lay over and it will knock the cobwebs out. Anyone else experience this?
Old 06-03-2011, 02:33 PM
Yes. In my 23' Tsunami, if I wasn't trimmed properly and quartered a wave of more than 2', the planing surfaces would hit flat and do a fiberglass belly-flop. Trim tabs fix that problem, though. I didn't have them.
Old 06-03-2011, 07:11 PM
cdavisdb cdavisdb is offline
My 2 cents to a common question.
Can't comment on the 23, never been in one, but I don't see any reason it would be much different from other Seacraft hulls.
I've owned and/or run in 20-28 ft deep V boats since about 1972, Seacrafts, Seabirds, 23 Formulas, Bertrams, SeeVees and a few more. In its size class none rode as well as the Seacrafts. A few anecdotes.
In the 1980s I was a member of the St Pete Underwater Club, about as "go for broke" a bunch of spearos as you will find, who thought nothing of going diving way offshore in weather most folks would not leave the dock in. Our boats mostly ranged from 23-28 ft. The few 20s were all Seacrafts, because no other 20 ft boat could deliver the ride we needed or stay in one piece under the punishment. I owned a 20 Seafari most of that time and regularly dove 20-40 miles offshore.
For a decade or so I owned a 24 Seabird, 24 degree deepV, well known and respected, very good riding boat. It took me to the Bahamas many times. A couple of years ago I was fortunate to acquire a Moesley designed 25 Seafari, slightly longer, same weight and beam as the Seabird. There was absolutely no comparison in ride, like trying to compare a soap box derby winner with a NASCAR champion, just no relation. Trying to go to Bimini in 3-4 was slow cruel exhausting punishment in the Seabird. I hardly notice in the Seacraft. I haven't had a chance to try it but I think equivalent discomfort would be about 6 ft for the Seacraft.
Last summer I was able to compare with a couple of ~30 ft twin outboard deepV center consoles. Gulf Stream, wind 15-20 for several days, seas a solid 4 then 5 ft in places. Running straight into it, the CCs were jumping out of the water up to the props, everybody in the back and standing up. At 4 ft, I was sitting down amidships and running my normal cruise of 22 knots. At 5 ft I had to slow down to 18 or so, but kept my seat. Granted they were running faster than me, but they were a lot bigger and nobody in those boats looked happy while I was comfortable.
You can believe what you have heard about Seacrafts, its true.
Old 06-03-2011, 08:53 PM
travisrandall travisrandall is offline
I have buddies that tell there buddies have you ridden in Travis' Seacraft. I talked to Diego who I bought it from and he would be glad to have it back. He said it rides better than his 30' customize
Old 06-03-2011, 11:05 PM
Good in beam or following seas?
I haven't found a bad wave angle in my 25, even quartering, which surprized me. In 6-8 ft, and breaking, following seas, conditions where other boats I'm familiar with would get pretty squirrely, the Seacraft felt like it was on rails, could have been flat calm for all the boat cared. I don't remember my 20 having any issues with following seas.
The 25 is sharper than the 23 or 20 and needs tabs. It rolls more than either, but not near as bad as a 23 formula. It is also very sensitive to the helm and it takes a few days to learn how to bring the bow down perpendicular to the waters surface when its jumping. Very easy once learned, even when its quite rough. That said, its not a boat for the inattentive helmsman.
Old 06-04-2011, 11:22 PM
riptide riptide is offline
Hey bgreene.I think we may have talked on the phone a few years back about that Sceptre for sale in Barnegat.Well I bought that one and totally refurbished it.Its a great riding boat and took me some time to learn how to drive it.
When you hit the chop your instincts tell you to slow down but actually you need to speed up to get on top and the ride smooths out.Head seas she cuts like a knife.Quarter seas seem to hit the chine and will knock your fillings loose.Following seas no problem.You need to trim to compensate.Coming from a Mako 228 she rides much better but not as much as I expected.
Jerry
77 Sceptre 250 Suzuki
Old 06-05-2011, 12:55 PM
pelican pelican is offline
for what it's worth:
mine 23 cc is a beast ! set the tabs correctly,and you're off ! that rig runs circles around my old 250 mako,runs circles around my old 31 bertram too.she's wet on a following sea - but,what center console isn't wet ?
she's not going in this season - it's headed inside my shop for a new deck,and a pilot house.
my rig's a stern drive set up - it's quiet and super fuel efficient - i run that rig year round - it's a little cold in the winter,out wreck fishin'...
