Old 06-14-2011, 09:35 PM
ElBichoMalo ElBichoMalo is offline
Default glassing tight corners
Anyone have any tips for glassing tight outside corners, such as in wrapping the edge of a piece of plywood, for example? I struggle with getting this done cleanly, without air getting trapped....Would love to know the right way to do this before I finish cutting my deck out...
Thanks,
Evan
Old 06-14-2011, 09:40 PM
SBD SBD is offline
Default Re: glassing tight corners
If its a square edge it aint gonna happen. You can get a wrap with a radius and the right cloth.
Old 06-14-2011, 09:55 PM
Sean's right. Any time I'm laminating an outside plywood corner, I run the router over it with a 3/8" round over bit. That's still a little tight unless you're using mat and thin cloth. Inside corners are easier, just build a fillet with thickened resin.
Dave
Blue Heron Boat Works
Old 06-18-2011, 10:22 AM
SBD SBD is offline
Thats a much better explanation of what I was trying to say.
Old 06-18-2011, 05:41 PM
putting some gloves on and working it by hand pulling it down helps too...
