Just really got to stretch out my boat this past week. A 20' MA with 150 Yam 2 stroke. With two guys and 30 gallons of fuel she would only turn 5200 with a 17 pitch prop? I can't believe I have to go to a 15. What are you guys running on your 20 MA's?
First on the trailer move the motor to neutral trim - get a yeardstick or some long striaght edge and see where the Cav palte is in relation to the hull bottom - should be at least 1" above and shoiuld be a bit higher. Then start with props, you should be able to swing a 17, but your not far off
Any way you measure it - dumbass is expensive |
Thanks Dog, I didn't think about that. I'll check it out.
