Old 06-26-2011, 09:48 PM
Default Foam In 20 cc
Just got my secraft this weekend And I've got some questions.
In the front storage compartment for The anchor I guess. Has no bottom but there s some wood particle clogging the drain holes. There it some flotation fom I can see below. In the forward deck hatch sombody had filled it with foam also when the hatch is opened If I was ro dig it all out could this foam go all the way to the forward foam I see or should there have been a compartment box below the hatch.
whY was the hatch originaly
82 seacraft 20SF
Bayview Canvas
Old 06-27-2011, 10:57 PM
Default Re: Foam In 20 cc
This is the forward compartment you can see the inside of the bow eye there is foam filled I. The bottom would this have been a empty void stock ot is there a bottom / floor missing. ?
Also the forward smaller hatch in thebbow deck also has fom under the lid. If I was to dig this out should I find a compartment live the bigger fishbox behind it ?
82 seacraft 20SF
Bayview Canvas
Old 06-28-2011, 10:35 PM
Someone did a number on that, start cutting and breaking it out of the anchor locker or fishwell and see if the liners are still in there or what the story is.
Old 06-29-2011, 12:47 AM
Thanks would the area below the vow eye just be empty space were the foami is or would there be a ottom od there. I had some wood remnant
82 seacraft 20SF
Bayview Canvas
Old 06-30-2011, 11:42 PM
82 seacraft 20SF
Bayview Canvas
Old 07-03-2011, 01:31 PM
Any info about undress thebbow eye should it be an empty void or a deck if the foam is removed ?
82 seacraft 20SF
Bayview Canvas
Old 07-03-2011, 10:05 PM
Jon G Jon G is offline
The area under the bow eye is a open area, I keep my small anchor in there, its finished with gel coat with a drain hole to the bilge in the bottom. What a mess someone left you get that stuff out of there Good luck with your project.
Old 07-04-2011, 12:18 AM
Thanks sei g they added the foam here I was wo dering was thee foam under the decks originaly? I also heard that the stringers have no wood in the older years I'd this true?
82 seacraft 20SF
Bayview Canvas
Old 07-04-2011, 12:26 AM
ya, it tru, no woody, jus foamie in da stingers.
diggy alla foamie outa boxie an u be bettar.
sammy
Old 07-04-2011, 04:08 PM
Anks Sammy good to know
but is there floatation foam under the decks or nit and this I'd whybtheboast owner added some ?
82 seacraft 20SF
Bayview Canvas
