Old 07-19-2011, 08:02 PM
muddywater muddywater is offline
Default Stupidest thing you did on your project
I can't be the only genius (sarcasm) here who did something stupid on their project. Here is my most stupid moment so far. I had this nice perfectly flat piece of plexiglass and started thinking it would make the perfect backing for a large area I needed to fill in. I normally use visqueen over plywood but it leaves these annoying ripples in the surface. Google said that epoxy wouldn't stick to acrylics. Um... I beg to differ. I now have a huge chunk of plexiglass permanently affixed to my hull (at least until I take a grinder with a cutting wheel to it). Time to invest in some partall and formica (shortcuts don't payoff).
I can't be the only idiot here. What kind of mistakes did you guys make on your projects?
Old 07-19-2011, 08:27 PM
Default Re: Stupidest thing you did on your project
Come on Muddy, you preachin' to the choir here!!
Any time you buy a project anything something stupid
is bound to happen...
I should know.... By the time I reach 115 years old
all of my projects should be complete.. NOT!!!
See ya, Ken
Old 07-20-2011, 02:41 AM
Starting one.
Old 07-20-2011, 08:58 AM
Starting one.
Amen! Then realizing that you must finish the project to get back 1/2 your investment otherwise you are screwed blued and tattooed...
Old 07-20-2011, 09:22 AM
TUGBOAT TUGBOAT is offline
Starting & Finishing a Project,After 18 Months & $$$$ , Then MOVE and letting It sit for 5+ Years!
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 07-20-2011, 12:23 PM
Replacing my through-deck scuppers in my 20', and only measuring one side for depth/length. I cut both scupper tubes and got ready to install after the epoxy cured. Turned out the other scupper was almost 1/2 inch longer.
Old 07-20-2011, 12:55 PM
Keyscruz Keyscruz is offline
Contemplating the many stupid things done boggles the mind. It is like a trip down gastric distress lane. I have narrowed the list to just under 100, all tied for first place.
Old 07-20-2011, 01:22 PM
Not using enough MEKP to catalyze resin (or using enough maybe a bad batch that was old) on the first layer of the first bracket I built . . . then trying to pop it out of the mold. Still don't know for sure, but removing the uncured resin and fairing an sanding almost ruined me. Thank god for chuck (strick) and Jorge to help me through the process.
Old 07-20-2011, 08:17 PM
Tiny Tiny is offline
Replaced a starter on a 350 chevy inboard (23 Dusky) while doing some other motor work...for three weeks the boat would not run...sounded great when turning over, but wouldn't start. Spent many days trying to figure it out. Then when standing by the exhaust muffler while it was being turned over...i heard a sucking noise... that's when i realized the starter was spinning backwards...after that if fired right up :-)
Old 07-21-2011, 01:29 PM
the stupidest thing i did was sell my project 23 SC. now im stuck with a 23 contender...
