Old 08-10-2011, 03:17 PM
Yz2009 Yz2009 is offline
Default 20' max capacity
Ive got a 87' 20' sf. I have searched around and looked at the brochure for the 82' which says the max weight is 1500lbs. I'm guessing based on reading other threads that is for persons, gear, and engine.
I have
450lbs of engine and battery
420lbs of gas when full
~200lbs gear? (I'm guessing between fishing and safety)
Then I have to factor in electronics and rigging?
So to be under the legal limit of weight I can have about 3 men? Is this right?
Old 08-10-2011, 05:27 PM
Default Re: 20' max capacity
The max load capacity rating for a vessel does not include full fuel load, that's merely part of the vessel's max gross displacement. It does include propulsion machinery only when that propulsion is externally mounted, i.e., an outboard motor. Max capacity does not include inboard or stern-drive weight in vessels so equipped.
The max persons rating is based upon 140 lbs average per person. That's the average weight of all persons: including men, women, and children in the average. Obviously, if those persons are adult men, you need to re-figure.
Old 08-10-2011, 07:06 PM
OilFieldMan OilFieldMan is offline
Fr. Frank,
Im slightly confused because you contradict something written in the specifications section. For a 20 SF it states "Outboard capacity - maximun total weight, persons, motor and gear in lbs -1508" the way that reads I would conclude the motor is to be included in that figure. Am I mistaken?
1974 Seacraft 20' SF with 1985 Evinrude 150 VRO
1987 Seacraft 23' Scepter with 2007 250 HP Evinrude Etec
Old 08-10-2011, 07:07 PM
and yields a different number with a stern drive unit vs outboard
Old 08-11-2011, 06:21 PM
Fr. Frank,
No, you are correct, and I am not mistaken.
I said,
emphasis is new
An outboard is externally mounted propulsion, and so is included in the weight calculations. Max load in this case includes the weight of the motor.
In a stern-drive or inboard, the listing is normally "Maximum capacity: Persons and gear", (motor is omitted) as the propulsion machinery is part of the vessel weight, not the vessel's capacity.
Old 08-11-2011, 10:43 PM
ok cool thanks, good to know that fuel doesn't count as carrying capacity
Old 08-12-2011, 02:38 AM
Count the life jackets - just say'in
