Old 09-07-2011, 10:21 AM
jobu jobu is offline
Default Main fuse/Scepter?
I lost all electrical the other night exept for the ignition and bilge. I had everything running that is wired to the bus panel. To save me the hassel of searching, does anyone know where the main fuse is or breaker?
It's an 88 Tracker/Scepter 23'OB
Thanks,
Joe
Old 09-07-2011, 09:03 PM
BigLew BigLew is offline
Default Re: Main fuse/Scepter?
Do you mean the main 12V. feed from the battery to the bus bar? If so, I don't remember ever seeing one.
Did you do a continuity check from the bus bar and the battery? Is your wiring inadequate gauge to carry the amperage drawn by "all" your electical equipment? If I were you, I'd start there.
But thanks for the question. I think it would be a great idea to have a circuit breaker of some type for the main power line to the bus bar. And if you hide it, it may stop an otherwise thief from stealing the boat for a joy ride or worse.
Plan accordingly!
