Old 09-20-2011, 12:04 AM
Max_Florida Max_Florida is offline
Default Gelcoat Cracks Along Gunnels
This pic is a bad example but it was the only one I took for some reason. I have cracks similar to this around every screw hole all along the gunnels.
For the cracks in the pic I was thinking I would have to grind the area down and put in some fiberglass.
For the other cracks that aren't so close together I was planning on grinding each one out with a dremel and filling with epoxy-filler.
I plan on painting the boat eventually(after I re-do the transom this winter) so I'm not worried about cosmetics right now, just functionality/durability.
What do you guys think?
The holes were where the port side stern cleat was mounted on top of a piece of thin wood.
Old 09-20-2011, 12:33 PM
Default Re: Gelcoat Cracks Along Gunnels
Yeah, thats what I would do.
Old 09-20-2011, 01:39 PM
Tashmoo2 Tashmoo2 is offline
I would be careful leaving epoxy exposed to sun,. it should be painted. you can sand paint off later
