Old 01-17-2012, 10:02 AM
fdheld34 fdheld34 is offline
Default Original Gelcoat colors for 70's 18SF?
I have decided to go with a close original color on my 18 SF. ..what were the original gelcoat colors back in the day?? I still cant get the search function to work!!!
All help appreciated!
-Fred
Old 01-17-2012, 04:46 PM
Fred - It's tricky to match the white color. I think I got pretty close on my 23 using this recipe.
a pint of Natural gelcoat
a pint White gelcoat
approx 1/2 teaspoon spoon of halyard off white pigment from UScomposites
(and then mix entire batch with 25% clear duratech).
Start with a smaller batch and use an eye dropper (with the pigment) to achieve desired color. As you get close to a match . . . test by putting drops on the boat to match (without MEKP hardener) . . . just wipe off with acetone.
Spraying with Gelcoat is a LOT more work than paint. You will prep the surface . . . spray a bunch of coats . . . It'll look like crap with all the orange peel. Then you get to sand with 320, wetsand 400, 600, and buff with rubbing compound/polishing compound and then wax.
http://www.uscomposites.com/pigments.html
Old 01-17-2012, 07:48 PM
Hi Fred, heres the page from the 73 catalog as posted in the literature section:
Old 01-17-2012, 11:16 PM
-Fred
Hey Fred,
If you can just get a sample of the gel coat to Tom Fabula in Hobe Sound (take him a hatch cover or something), he can mix up some Signature Finish paint that will perfectly match the gel coat, but it'll be a lot more durable than gel coat! The "Denny White" he mixed up for my '72 boat might be close, or at least a good starting point. PM me if you want his address. Denny
Old 01-18-2012, 08:35 AM
Default Tom Fabula
Tim-thanks for that info. love the eye dropper idea. I had a heck of a time matching gelcoat on that transom redo I did on the grady.
Gille...thanks for the help...my computer skills must be declining...just the info I need!!!
Denny--I tried to call Tom but a bad number??? Might go by his address
I'll drop you an email
-Thanks all,
Fred
Old 01-18-2012, 11:10 AM
htillman htillman is offline
I got normal white from Signature Finish, took a hatch cover to the local Sherwin Williams store, gave them a few bucks and they matched the color almost perfectly.
Old 01-18-2012, 11:25 AM
MiniCraft has successfully matched the gel coat on a couple of older boats for me. If they have a file on a particular model, you may not need to pay for a custom match.
http://www.minicraft.com/
1974 23' Tsunami, fully refurbished, custom pilothouse, Hermco Bracket, 250 Etec
1977 23' Sceptre fully refurbished, soft top, I/O
Old 01-18-2012, 01:40 PM
Thanks all for responding..still trying to get a hold of Tom Fabula..to go with Signature finish instead of gelcoat.
htillman sent you a pm
-Fred
