Prop for a 190 200hp Johnson on a 20' SF
Can anyone point me in the best prop for this scenerio.... I believe I have a stock aluminum prop right now and get about 5000rpms until she starts beeping the low oil warning horn. Wondering what sort of props I should look at. Think the fastest I ever went with a GPS was 43mph. I feel like there's more I should get out of it. Before I go into researching props I'm sure someone might have had this setup before and knows more than I do.
Thanks so much for any advice! The motor is also a counter rotation that I picked up from an old grady white pair....it was cheaper than the other one....was working on a budget. Iceboy |
Quick question...."low oil warning horn"??? Not the temp/overheat horn sequence of beeps?
Oh yeah, a 1990, right? Carb engine? Pitch and diameter of the prop?? |
Or maybe a fuel restriction alarm?
I would think it would swing a 3 blade sst 21 pitch if the motor is a strong motor but a 19 pitch of the same prop may be the ticket.
Thank goodness that in the scheme of things you are broke, powerlesss and inconsequential, because with the shortsighted alternatives and idealogy you have you'd be much worse than those you complain about. |
FWIW i run a 200 mariner on a 20' SF and i run a 21p laser2. I max out at about 5200rpm lightly loaded. next summer im thinking of going to a lesser pitch prop. the enertia 19p has been catching my attention or the 17p or 19p mirage plus
Thanks guys, I'll start checking on those props! I just checked and my prop is part number 431930 and says 15x17 on it.
I'm pretty sure the horn I get is low oil horn which chirps every 2 to 3 seconds. I don't think it's the low fuel warning which is continuous. I have 3/8" fuel line and the big Sierra 18-7866 fuel filter(10 micron). It's always happened since I got the motor. I even switched the VRO once with a 1994 VRO and the same thing happens...I pretty much only run up to 4900rpms or below. And only 4900rpms when we're showin off. I go pretty easy on her since it is an older engine. If I can figure how to post pics I will. I haven't in three years since I redid her. Thanks so much again! Dave |
Cavitation plate is either right on the transom line or slightly above, maybe no more than an inch. I just put this motor that I bought apart from the hull in the same holes that were there from the factory I guess in 1983 and everything lined up. 25" shaft.
# 1 - Since is an older Rude DECARB DECARB - maybe twice LOL -
#2 seems like it should swing a 19 but it seems to like a 17 based on your RPM - I love the Stilletto I have, such tremendous change and so trim responsive. You can find them used on ebay too for less than 200 - 150 is great. You will have to raise the motor as stated to 1.5 to 2" above when going to an SS prop, 2 at least if you go with a stiletto or mirage. Alot of guys like the Mirage although I can't compare - I couldn't find one #3 you really need to figure out what the alarm exactly is, your on a budegt you don't need to lose it. The best way to explode an older OMC is NOT decarb it - the carbon builds up in the ring glands - motor will even run alot better too with more compression. My fav is Seafoam - get the lawnmower can 1 or 2 gal , follow the directions - I think they say 50/50 gas and Seafoam - 1 gal of fuel is fine. Warm it up on the muffs good - pull the fuel line off and stick it in the can and fire it up - again follow directions, run 15 mins sit 15 until gone. WARNING - have it in kinda open ground, it will smoke a tad, kinda like a peat fire - he he call me if you have any questions - that is imperative - 813 286 8344
Any way you measure it - dumbass is expensive Last edited by eggsuckindog; 01-31-2012 at 10:25 PM. |
Dave
Blue Heron Boat Works Reinventing the wheel, one spoke at a time. |
Since I'm on a recent rebuild I haven't done it in awhile - so thats why I kept saying follow directions
Any way you measure it - dumbass is expensive |
