Bravo2 out drive with complete Gimble assembly
Hi I have a 1993 bravo 2 outdrive with gimble assembly and a mercruiser 5.7L 260 hp Serial number are engine0F117797,,, outdrive 00869758,,,,transom plate 0F207033
engine model number 4-57B110GS. THe engine turns over but needs an to be rebuilt Been sitting for 8 years in the boat on a lift Has freshwater cooling.. the outdrive is in good shape needs new boots and trim cylinders need new seals. Comes with all controls ... converting to outboards.. I have all paper work and recipts for the engine package HTe owner bought a new package in 7/10/93 . Always kept it maintained until his health failed then he lost interest .. The boat was last registered in 05 and I am sure it did not run much after 06 If you need it delivered I can accommodate Just need a zip code business address $3450.00 OBRO plus shipping Will be pulling motor and drive March 3rd I will have better pics then Call 8506247403 or pm me Last edited by martin; 03-04-2012 at 10:15 PM. Reason: lowered price |
sent payment via paypal bank check!! Thanks
pictures
Pulled the outdrive off and inspected the gimble bearing.. Looks brand new.. the shaft and splines on the Outdrive are excellent shape as are the ujoints.. it comes with a 21 pitch cupped prop from power tech item # m400bra 21pitch ... this unit did not get much use when installed in have all paper work that shows the maintenance since 05 last year it was registered.. Pulled the motor out the exhaust and riser where spotless . there is not water in the engine. The heat exchanger was spotless. No corrosion whatsoever. There was fresh antifreeze through out engine. oil was clean ,distributor clean,needs new alternator and rebuild raw water pump...
bravo outdrive and assembly
new price 2500.00 firm
New Price
1750 OBO for Gimble assembly and foot I need it gone Thanks Martin
