Old 03-05-2012, 10:00 PM
ChampionShip ChampionShip is offline
Default Hard Top Plans
Thinking about building a hart top for my final project for this semester's Marine Composites Class. We're building from a mold (required) but I need input on what others have done in the way of fiberglass. Which glass did you use? I will be using balsa for a core. Any other tips would be much appreciated!
Thanks!
Old 03-05-2012, 10:17 PM
pelican pelican is offline
Thanks!
if i was making a hard top - i wouldn't use a balsa core,or any wood core - due to the fact,there's gonna be holes made in the top - lights,antennas,etc - holes and wood do not play well together...
when you state "hard top",just the skin ? "skin" meaning the top,not the framing ?
Old 03-05-2012, 10:32 PM
What kind of core would you use? We can use honeycomb, foam or balsa. Could just skin a piece of marine sheet i suppose?
Old 03-06-2012, 01:10 AM
Corecell works great for a hard top. I built this one several years ago. Click on the link and there are a few pic's of the build.
http://www.casdvm.com/photos/Hardtop/index.htm
Old 03-06-2012, 01:30 AM
What kind of glass did you use and how was the compressive strength of the coracell? It's gotta hold antenna masts and a radar eventually
Old 03-06-2012, 11:58 AM
csurf csurf is offline
Really nice work Strick!
1980 23' SeaCraft
1992 16' Steiger Craft - Custom Flats Boat
The sea finds out everything you did wrong.
Old 03-06-2012, 05:08 PM
saugeye saugeye is offline
Give Champs some good advice please. He is building it for my boat, the former Entourage, 73 tsunami.
73 tsunami
Old 03-06-2012, 11:01 PM
composites,should be thru bolted and "sleeved"...
a "skin",you can make just a skin - provided there's antenna plates on the framing
use the mold,wax it,coat it out in gel,and lay up some matting - 1.5chop strand,2 layers of 1708,and another layer on 1.5 chop strand...gel coat the exposed side -done...
the mold you've got - angled radar mount made into it ?
if it were me,i would use a foam composite - no way on wood coring for a hard top...
Old 03-06-2012, 11:06 PM
Can't wait to see this one. I used a foam core on mine it is very light and strong. Was made in a mold though (chop gun etc.)
I agree there, wood will rot and is too heavy way up in the air like that.
