Old 03-17-2012, 11:06 AM
bilgerat bilgerat is offline
Default 73 seafari 20/ updated with new photos
back on the market
25$ paid Transaction ID # 52R25949EL712962H
As much as I hate to Im going to have to part with My 1973 Seafari 20 to fund the fixing up of My 72 25'er.
so....
1973 Seafari 20 with a 1988 Mercury 75hp W/ SS prop and a 8hp evenrude kicker
solid boat with no soft spots in the floor
heres a list of the things Ive done;
new steering system
new fuse and switch panels,
new washdown pump , thru hull and hose
new west marine cd stereo w/new speakers,
new VHF radio and antenna
New rod holders,
new volt and gas guages mounted in teak panels
New custom built radar arch with rocket launchers rod holders and I moved the mast light from the windshield to the arch
new spreader lights
new bilge pump, hose, and float switch
new compass,
new stern light a
new airator pump in live well,
new cabin light
all above installed with new wireing
2 batteries [1 new] with new perko switch and new battery cables, I moved the batteries to the front under the center seat in the cabin and installed gill battery hold down trays
40+? gal alum fuel tank, I pulled the tank and had it cleaned out and replaced the fill and vent hose and the fuel sender in tank ,added new fuel lines and H2O seperator filter with selector valve to run the kicker,
both engines have new impellers ,tune ups, lower unit lube and fuel lines
Both run great
New colmbing pad Ulpostry
other stuff I added that the boat comes with ;
bimini top, and boot
teak swim platform w/ladder,
SS fender baskets,
theres a few things left I was gonna to do,
{DONE}one of the cockpit drains in the floor, I replaced one with a brass threaded thru hull but havent got to the other side , Its filled with epoxy from the top and bottom to seal it up. { Other drain is now installed}
replace the tach
replace the headliner and seat cushions in the cabin , they are missing,
replace cabin door with a teak one {the door was missing when I got the boat so I built a plywood door and varnished it } looks and works OK
It could use a good buffing, some day I was going to paint the boat but......
the transom has a plate but seems solid, It was replace in the 90's
NEW;;; now has a 1990 alum trailer
4500 obo over 6 invested and many of hours
Located in N Georgia
Phil Davis
{AKA} Bilgerat
