Old 03-27-2012, 01:07 PM
StAugSeacraft StAugSeacraft is offline
Default SOLD --- 1973 Sea Craft 20' Center Console Suzuki 2005 DF 140 Four Stroke
Don't miss out on this Classic Center Console. See this 1973 Classic Sea Craft SF 20 Fighting Lady Yellow Powered by a 2005 Suzuki DF140 (approximately 525 hours) with three blade stainless steel prop.
Upgrades and Options Include New water pump installed spring 2011. Boat averages 3.5 miles per gallon. 2005 Continental Aluminum Float On trailer, new heavy duty springs installed Fall 2010. T-Top with 4 welded rod holders, new canvas installed Fall 2010. T-Top Bag with 4 Type I offshore life vests. Leaning Post with four new 316 Stainless Rod holders, removable cooler underneath. 27 gallon plumbed oval live well installed in Fall 2010, Garmin 400C Dual Frequency Color Depth Finder, serviced by Garmin and re-installed in spring 2011, New BOSS Marine 4X60 Watt CD/MP3 player with Aux input installed spring 2011, New Cobra 25 Watt VHF installed spring 2011, Ritchie Compass with backlight, 4 6X9 Audiobahn speakers, New Rule 1500 GPH Bilge Pump with standalone Rule-A -Matic float switch installed spring 2011. New Rule 800 GPH Bilge Pump Manually engaged via dash mounted switch panel installed spring 2011, New Rule 500 GPH serving the Baitwell and Washdown pump installed spring 2011, New FloJet Washdown pump installed spring 2011, New LED Nav Light installed spring 2011, New NoFeedBack Teleflex Steering installed fall 2010, New Blue Seas Fuse Panel/Bus Bar with Lighted and fused Rocker switches, waterproof installed fall 2010.
New deck installed fall 2010 done by a professional shop (Three Brother's Marine). The entire deck and step up front deck were replaced. The main deck was raised 3 inches. The boat was gutted down to the stringers and built back up. Rear bait well was removed and a new access hatch was molded to access the pumps and bilge. The console was customized to accommodate the new 27 gallon oval bait well under the front seat with piano hinge. The console front seat was raised 4 inches. Taco Marine Telescoping Outriggers with T Top Mounts. New TH Marine Flow-Max Ball Scuppers (3), easy removal to clean.
There are more pictures at the link below. I need to move the boat for financial reasons. You can see I recently put a good chunk of money into it doing things the right way but stuff happens. Make me some offers please!
More photos located here....
http://smg.photobucket.com/albums/v3...ki%20DF%20140/
Asking $11,999.00 - Bring an offer!
Posting Fee Paid
Transaction ID: 5H6233604A930562D
Thanks!
