Old 03-29-2012, 06:04 AM
shana shana is offline
Default transom rebuild
has anyone used evercoat kitty hair to laminate plywood to skin and between layers of ply thanks
george j victor jr
Old 04-01-2012, 01:21 PM
76 hit and no help
george j victor jr
Old 04-01-2012, 01:54 PM
Wildman Wildman is offline
Just use 1.5oz mat between the layers of plywood. Also use a layer between the original skin and the first piece of wood. Much better, (stiffer,stronger) than any bondo product.
Old 04-01-2012, 05:38 PM
George - Kitty hair is essentially bondo with milled fibers . . . you are much better off with 1.5oz mat and polyester resin. The resin will absorb/sink into the plywood and make a strong bond.
Old 04-01-2012, 06:05 PM
hermco hermco is offline
Using kitty hair might be cat-astophic!
Old 04-01-2012, 07:09 PM
BigLew BigLew is offline
Don,
That was a bull's eye. Nice shot! All in fun!
Plan accordingly!
Old 04-01-2012, 07:41 PM
If your going to bond plywood to skin you can use the method everyone is saying. But i would get epoxy and thicken it out to a mayonnaise consistency with the powder thickener then apply with a trowl. You will have to grind this apart to separate. Epoxy makes the best bond when applying 2 pieces together.
