Old 04-18-2012, 09:19 AM
Abe's Rocket Abe's Rocket is offline
Default Fuel Fill...back up
I've been getting some backflow when filling the tank on my 23ft. We've replaced the vent on the outside of the hull and its still backing up.
Is the next step to replace the hose from the deck to the tank? I'm nervous about that being the an enormous project. Has anyone else had this issue?
Thanks!
1986 Seacraft 23CC
etec 250
Portland, Maine
Old 04-18-2012, 04:49 PM
pelican pelican is offline
when this occurs - it's usually a kinked vent hose...
Old 04-24-2012, 03:49 PM
This sometime happens if the vent hose is blocked. I've had water/ fuel stuck in mine before. Try unhooking the vent hose from the fuel tank end and blowing on it, that usually does the trick.
Old 04-24-2012, 04:38 PM
Sometimes mud-dobbers build dirt nests in or around the vent and/or hose attachment area.
Old 04-24-2012, 05:01 PM
no its not the vent - the fuel fill line has a low spot somewhere - when doing a sending unit I moved my line off a pile of foam - bad bad move, created a low spot. I had to pull it again put it back up there and it got better again. Maybe try shortening it, disconnect it from the fill and pull it as tight as possible and straight as possible - easier than pulling the hatch - worth a try.
Old 04-27-2012, 07:44 PM
With all due respect, it MAY be a low spot, and it MAY be the vent, as every time I have problems filling mine, it has been the vent hose. Also, i have an inspection hatch that accesses the op if the tank, so the whole process takes about 5 min.
Old 04-27-2012, 11:58 PM
He said he checked it already, I have to believe him
Old 04-28-2012, 03:15 PM
Yeah, I guess he did. I thought he was just referring to the vent itself, but not the vent hose. Check it all! Good luck!
Old 04-29-2012, 08:38 AM
I gueese ive never had a blocked vent line what exactly happens (backflow)?
82 seacraft 20SF
Bayview Canvas
Old 04-29-2012, 11:28 AM
not exactly but it would try and vent back up the fuel fill - kinda like a lawnmower can without a vent. Vent issues will cause the bulb to suck flat as you run trhe motor
