Old 04-28-2012, 05:01 PM
tautog_33 tautog_33 is offline
Default 20 SF Drive by
Took the seacraft out looking for a spot to mount transducer on the transom while the wife drove I think I might just drill the big hole in the bottom and go thru hull. It looks like too much disturbance for a transom mount. Is anyone out happy with their transom mount application?
The wife captured a couple videos enjoy.
http://s1103.photobucket.com/albums/...acraft%2020SF/
Old 04-28-2012, 08:18 PM
Wildman Wildman is offline
The thruhull is the way to go for sure. It only hurts drilling the hole, after that its cake. They cost more, but they work much better.
Old 04-29-2012, 09:23 AM
X2. I have the Airmar B164, works great. I went with the 1000w system, if you use the 600w unit it's a little cheaper.
"It only hurts drilling the hole, after that its cake".....how true!
Old 04-29-2012, 01:39 PM
I cut out my in deck live well and was thinking of mounting the thru hull transducer B60 about 23" from the transom on the starboard side. Would 23" be to far forward? Thanks in advance for any feedback.
Old 04-29-2012, 02:03 PM
I used the location where the high speed water pick up was already located on the starboard side, it was easy to get to (I moved the water pick up to the port side). It's about 30' from the transom. Looking at the Airmar web site's mounting instructions, I think you should be real good at 24" or so. Put it in the easiest location....in the flat area between the chines....for you to get to and work on. It hurts to see a 3 3/4" hole saw going through the hull, but when done it's worth it.
http://www.airmartechnology.com/uplo.../17-364-01.pdf
Old 04-29-2012, 02:08 PM
Actually mine is closer to 30" from the transom. Whoops.
Old 04-29-2012, 02:30 PM
DonV Thanks for the response I'm going to drill the hole and use 5200 to seal it up. http://www.classicseacraft.com/commu...ons/icon10.gif
Old 04-29-2012, 07:24 PM
TooFly TooFly is offline
I don't think my existing Garmin (port side) is even 24" from the transom. It worked well, though. I have a new Airmar that I'm hoping to install in its place. Some schmoe decided to 5200 the Garmin thruhull. I'm going to have fun drilling it out this week.
1969 20' Potter SeaCraft
2007 150hp Evinrude E-TEC
Old 04-29-2012, 08:15 PM
TooFly I've heard of using a thin steel wire to cut through the sealant and free it up some. What other product are you going to trust below the water line?
Old 04-29-2012, 10:16 PM
I've got the side scan humminbird unit with a transom mount ducer . . . Holds bottom great middle of 2nd plane.
