Old 05-05-2012, 03:25 PM
jesusv jesusv is offline
Default surprise! wet foam in stringers
as i was removing the glass on the transom to remove the coring i cut back the stringers, as i mad my first cut midway up the stringer water begins rolling out. i made another inspection cut about 1.5 feet from the transom and same thing. what now? its a 23 inboard and im in south florida dont know if i should be putting this much time into an inboard, which is a great boat but realistically an outboard would be much better for so. fl.. thinking my time would be better spent on an outboard model. any suggestions, advice?
Old 05-05-2012, 08:22 PM
Put a bracket on it and convert it to an out board. You already have the full transom which is very desirable when it gets rough.
Old 05-05-2012, 08:43 PM
Ryan Ryan is offline
Will the prop tunnel effect his performance with an outboard?
Old 05-05-2012, 09:03 PM
Grneyedloki Grneyedloki is offline
turn it into an outboard with a bracket. best decision you will make
1974 23 SF - "Likes It Rough"
http://www.classicseacraft.com/forum...rt=&PHPSESSID=
Old 05-05-2012, 09:45 PM
From my understanding it doesn't workout well because of the tunnel
Old 05-05-2012, 11:37 PM
didnt think about that.
Old 05-06-2012, 09:40 AM
Aside ftom access to work on the bottom wouldnt it be relatively easy to glass over snd cOver the tunnel? Maby will the void with foam?
82 seacraft 20SF
Bayview Canvas
Old 05-06-2012, 08:52 PM
i dont know as to the ease of doing it, but i think before i did that i would end up buying or trading for an outboard or i/o model. just dont know if i should be that concerned with the foam being wet.
Old 05-07-2012, 12:12 AM
I just did it to mine you will have to do it to any of these boats that havn't been touched its foam just gut it and pour new the inboard is well worth it when your done just cut large. Access ports on the top of the stringers and then close them back up when done but don't destroy a true inboard there's not enough of them out there. Just think you will be the only boat going the same speed when the weather goes south
1979 Septer I/O no power Sold
Old 05-07-2012, 10:35 AM
If the floor is in good shape . . . I'd try to dry out the foam without ripping the boat apart. You can use a hole saw and drill a few 2" holes in the stringer (2" up from bottom of the stringer) to get a better idea of the situation. It's far easier to patch bunch of 2" holes than replace the entire stringer and floor . What I've seen in a few other boats is that only the bottom 1" of foam gets wet and the rest of the foam inside the stringer is dry . . . If that's the case just you can fix it easily without ripping the entire boat to pieces.
