Raw water pickup install
Which way does the "screen " face forward or backwards?
I will have a valve and a 500gph pump attached to it then to the baitwell |
Screen goes froward. In the middle panel port side. 3 feet forward of transom so as to let clean water get to the prop. It will ram my well while underway. Cut the threads on the pump as short as you can. Seacock or ball valve and wood pad for added strength and safety.
You can adjust the seacock valve so when under way your bait tank does not over flow. strick |
Thanks for the input
Those pump shafts are known to fatigue and fail so a valve is a must and easy access as well. The tnt should plug into your harness to the motor. Under the lower port cowl on my rude. |
Ininstalled mine on the starboard side under the motorwell so i could wccess working in it through the swuare access hole in the motorwell maybe a 1 1/2' forward didnt think of the ckean water but i. Have no trouble
Got installled in I think the same place as yours
Can't wait to use it |
