Old 07-16-2012, 10:39 PM
Rlbol Rlbol is offline
Default Which transducer?
Getting ready to install a raymarine e7d and need to order a transducer. I am going to go through hull but I didn't know which was the correct angle to order?
Old 07-16-2012, 11:36 PM
Erik Erik is offline
Default Rlbol
I have a PiranhaMax 160 fishfinder with a shoot thru ducer. My first ducer was triangular and it did not read. I just bought a puck and it reads very well. Supposedly, shoot thru ducers work best on single layer hulls. Good luck!
Old 07-17-2012, 06:08 AM
Wildman Wildman is offline
I went with a 20deg b60 ducer, mounted on the lowest part of the hull. Its a universal one that fits more than one machine, with a difrent pigtail. Call BOE marine and ask them if it will fit yours.
Old 07-17-2012, 08:21 AM
Patrick is correct! I've got the B164 20 degree mounted like he did and it works perfect.
Old 07-17-2012, 09:18 AM
Are these actually thru hull or shoot through hull?
I was thinking of the one. That actually gets drilled through the hull. I also looked at ones that mount in the hull but are not drilled through. Is there a difference? Which is better?
Thank you
Old 07-17-2012, 10:28 AM
Same here. It's true thru-hull mount.
Old 07-17-2012, 03:16 PM
forget shoot thru - its like mowing half the grass
Old 07-17-2012, 03:20 PM
How true ESD.....like being just a little bit pregnant.
Old 07-17-2012, 07:23 PM
Thanks guys
So 20degree is the correct angle for a 23 center console?
If any one has pictures of where there's is mounted could you post them?
Old 07-20-2012, 03:50 PM
I installed a shoot thru on a 34 silverton once it work fine in my case thought it ws t the fastest boat a d i did t want to have to pay for hauling the boat out to do it or the pia.
82 seacraft 20SF
Bayview Canvas
