Old 07-18-2012, 01:04 PM
kooker kooker is offline
Default Found the hull deadrise angle...what's my transom degree?
1971 20' SF....Used a protractor and it said 16...is my transom degree 14?
Old 07-18-2012, 09:19 PM
Use the protractor to measure your transom angle. I believe it's 13*
Old 07-18-2012, 09:33 PM
I placed this on the transom and it read 16. Was that the transom degree or hull deadrise? I'm so confused with finding the transom degree...
Old 07-19-2012, 09:40 AM
It's 12 or 13 degrees depending on the tide and wind. Give that thing a tap and try it again. I have the same contraption.
Old 07-19-2012, 01:19 PM
I put the flat bottom part vertical on the transom and it read 16. Is that giving me the hull deadrise or does that represent the transom degree?
Old 07-19-2012, 03:48 PM
What you're looking for is the angle relation between the transom and keel. Using that tool the keel needs to be zero.
Old 07-20-2012, 01:46 AM
transom degree
Old 07-20-2012, 07:35 AM
GoodChance GoodChance is offline
Is the keel level or tilted back by 4 degrees?
The Idiot Who Re-Built the Burnt-Up 35 Duffy
