Old 08-03-2012, 03:21 PM
bitsamonkey bitsamonkey is offline
Default 2011 Suzuki DF90 on an 18'
A tailwind, 14X18X3 factory stainless prop with added cup, 4800 rpm, full fuel, small passenger empty livewell, no top.
Old 08-03-2012, 03:55 PM
Briguy Briguy is offline
Is this the old 90hp or the newer lighter one? In any case, you should see at least 5500 rpms.
Capt. Brian
Old 08-03-2012, 08:47 PM
I want that 740s!
Old 08-03-2012, 09:20 PM
It's the new lighter DF90A. I hit the limiter at 6300 rpm and 37.5 mph.
Yeah, the 740 is nice and coming down in price. It's way faster than even the 5200 series.
I was really bragging about the 6.9 mpg.
Old 08-03-2012, 10:03 PM
Good to see you Bit`s.
Light is good.
You guys suck with your MPG off idle.
Cheers,
GFS
Old 08-04-2012, 11:42 AM
So, does the Suzuki require a special kit to convert the NMEA from the motor to give you fuel burn? I believe that's what I read when looking around. I'm looking at getting a DF140 for my 20' soon. 6.9mpg is great!
Old 08-04-2012, 01:49 PM
Yeah, you do have to configure the output with a lowrance unit or the suzuki digital multi function tach (made by lowrance). Once that's done it'll run on the Garmin or any other nema network. It was a pain, but well worth it. The fuel burn is spot on and it also displays trim, water pressure, water temp, engine hours and rpm.
My Suzuki dealer let me borrow one of the units to get it configured.
Old 08-10-2012, 06:25 AM
tomfl tomfl is offline
What is the top speed with that setup?
Old 08-10-2012, 07:18 AM
From the OP's post above:
Old 08-10-2012, 11:26 AM
Holy smokes! those are incredible numbers . . . you'll love that boat.
