Old 08-15-2012, 10:55 PM
littletunny littletunny is offline
Default SCUPPERS SCUPPERS SCUPPERS!!!!!I need your help!
I have come to the experts. The best of the best.
I posted my problem on The Hull Truth....Nobody would touch it with a 10 foot pole.
http://www.thehulltruth.com/boating-...ication.html#b
I posted on the Sea Hunt owners group. No concrete responses.
http://seahuntownersgroup.yuku.com/t...VING-ME-INSANE
Its time to get serious. Video here:
http://www.youtube.com/wa...5n1ae4I&feature=youtu.be
I own a Sea Hunt BX 22 with scuppers that are horizontal and is terribly slow to drain. I want install scuppers that are vertical like the ones from TH marine. Any tips?
Old 08-16-2012, 12:07 PM
Rondo Rondo is offline
Have you contacted Sea Hunt about this issue? They might be able to give you some suggestions. The vertical placement seems to be contributing to your problem, and I wonder what size your drain hoses are? I have two boats with floor drains and they drain freely. Do you have access to your drain lines? I would write to Sea Hunt @ 2348 Shop Road, Columbia, S.C. 29201 or call them @803.755.6539 and get their input on the problem. If they can't help, then I'd start thinking about alternate solutions. Additionally, Is it possible that you have some debris clogging the drain hoses? I would flush each line out with a garden hose held right up against the drain and see if you clear any debris out. I do it a couple of times a season because of leaves or other small debris that find their way past the scuppers.
Old 08-16-2012, 09:26 PM
The key to the good performance of the vertical SeaCraft scuppers is a wedge thats about 1/4" tall right in front of the scupper outlet, shown in picture below. It creates a significant amount of suction that really pulls the water out when you're up on plane. I suspect the aeration created by the adjacent vertical step between the center and outer panel of the variable deadrise hull also helps.
Second shot shows the aeration that reduces drag and makes these hulls so soft riding!
Old 08-17-2012, 01:32 PM
Thank you. Do you have a picture from your cockpit? Did you create the pad just for your scupper drain?
Old 08-17-2012, 02:26 PM
Originally Posted by littletunny View Post
. . . Did you create the pad just for your scupper drain?
If you're talking about that wedge on the bottom, no, SeaCraft's came from the factory like that.
There was a wood block installed between the hull and inner liner where the scuppers are. The brass tubes eventually corrode and start to leak, causing the wood to rot. Here's a couple of shots from the top I took when I repaired mine. I installed a pvc/wood dowel from the bottom to create a plug, filled the hole with thickened epoxy, redrilled the hole and then replaced the brass tube. There is a well about 3" across and 1" deep (2-3" deep in later models with raised decks) in each corner of the cockpit where the scupper tubes are located. You could probably create a more durable version of the same thing using a bronze or Marelon thru-hull fitting. But the wedge on the bottom in front of the outlet is the key to creating a lot of suction!
Old 08-18-2012, 08:41 AM
Bushwack. Thanks for the inspiration!!!
So I am kicking a few ideas around. I still need to determine if I should close off the old scuppers or leave them be. Of course if I close them off it will be a little more work fiberglassing.
I like your idea going straight down with drain pipe and not using hose.
I just have to find a spot in the cockpit run it thru. I have box stringers whch are about 6" wide so I dont want to drill thru those.
Old 08-24-2012, 01:41 PM
Littletunny,
I don't think Bushwhacker was actually recommending vertical scuppers.
Vertical scuppers are only good underway.
I would suggest you take a closer look at your problem. First determine why they drain slow. Diameter of drain tubing? Is tubing flange elevated causing water to exit uphill? What is height of floor in relation to waterline? Where do transom scuppers drain in relation to floor and waterline, etc...
Assuming the angle of egress is favorable, I would consider changing the size of the tubing and fittings and putting ping pong ball scuppers on the transom to keep water from coming in from the aft end. If the drains prove to be running uphill, change that angle. A factory error in that regard is very possible...
Old 08-24-2012, 03:29 PM
If you're concerned about self-bailing at rest, Gillie's right, the scuppers out the back with the ping-pong ball check valves work well, although debris can keep the balls from sealing.
However, if you're worried about quickly removing a large volume of water from taking a wave over the bow in what may be a boat with low freeboard (maybe a flats boat?!), I think the suction in the vertical SeaCraft type scuppers with the wedge forward of the exit will beat gravity every time! The SeaCraft scuppers are about 1" ID; going larger would also help. And if you go with vertical scuppers, make sure you can get rubber plugs for them, because you need the plugs unless your deck is several inches above the waterline!
Old 08-24-2012, 06:37 PM
This is something that butters my biscuits. Having fished on some commercial boats, I always shake my head in dismay when I look at new "small craft" and think to myself.....have any of your designers EVER taken green water in a small boat? Really, you think those scuppers are gonna save my bacon?
I don`t see scuppers on Wagons, I see CULVERTS. Things that can actually move water. What a concept.
As Gillie said, you must determine if they have a proper angle to allow gravity to slowly do its job.
Do you have water coming in at rest?
With 1 or two in the corner?
Do you have a heavy motah on the back?
We need more intel.
Do you have corrugated scupper lines or smooth hose?
Do you have flappers?
Have you called the factory?
I have thought about puttin` big honkin` oval scuppers in my rig.
Cheers,
GFS
Old 08-24-2012, 07:49 PM
"I have thought about puttin` big honkin` oval scuppers in my rig"
Hummm........Sandy, I'm thinking 3"x 6" oval would do the trick. Don't want to go too big because the bugs you catch and toss in the boat from your super secret lobster spots, while using your new Lloyd Bridges approved scuba gear, would slip right back out through the scuppers.
