Old 09-24-2012, 08:37 PM
martin martin is offline
Default Molding clay
Can anyone tell me if you have usesd clay from local hobby shops .. Was wondering if i can get something that will work locally for molds.. Or do u recomend the mold clay fiberglass co sell..materials will be here tues so i will be building decks soon.. Thanks martin
Old 09-25-2012, 06:04 AM
Hobby shop clay works as long as you don't get the kind that hardens when you bake it. It can be hard to find the old style oil based clay, but it works just fine. Make sure to get good coverage over the clay with your PVA or the oil in the clay will cause your gelcoat to alligator.
Dave
Blue Heron Boat Works
Old 09-25-2012, 07:01 AM
I like Permoplast clay.
http://www.hobbylinc.com/htm/aac/aac90055f.htm
Old 09-25-2012, 07:52 PM
Thanks guys...
Old 09-26-2012, 09:47 PM
What is the temp rating of this stuff thanks MJ
Old 09-27-2012, 08:18 AM
temp rating for what?
Old 09-28-2012, 09:24 PM
Default Clay
Of the clay.. Or am i digging to deep for info . Trying to find an equivelant .. I have some @150f... Wondering if it is the same
Old 09-28-2012, 11:28 PM
I'm not that much into it. I'll take a look at the box to see if there is a temp rating. I just put it on the mold and glass over it
Old 09-29-2012, 09:48 AM
If it has a temperature rating on it, it's probably of the polymer thermoset type I was talking about. You want the oil based stuff that doesn't set when you bake it. The thermoset stuff will work, but the oil based clays are a lot easier to work with.
Dave
Old 09-29-2012, 05:06 PM
mnwnvc mnwnvc is offline
I have been told that you should use a low sulphur clay when making silicone molds. Do not know if there is any reason to apply this advice to epoxy or glass. Sulphur in the clay can effect curing of silicone.
