Old 09-29-2012, 08:02 PM
vikingfish vikingfish is offline
Default 20' SeaCraft $2900 - 110 Johnson and Trailer
For sale is a 20' SeaCraft with 110 Johnson and LoadRite Trailer. This SeaCraft comes from a family estate, and does need a small amount of TLC. The transom appears to be solid, and the motor does turn freely with what seems to be good compression. There is a spot light on the bow that is remote controlled. There is an above deck fuel tank under the console that appears to be factory, as my '73 20' was set up the same way. The cockpit does have two areas that are soft, the hull looks as if it were originally red with a white imron hull spray. The SeaCraft also has a bow rail that was damaged during a snow fall along with the original wind screen, and both can be repaired quite easily. The SeaCraft is located in Southern New Jersey
This appears to be a mostly original 20' that would make a great part time restoration while still in use. All the parts and pieces are there to complete
For sale at $2900 Cash, or Trade for a running truck (looking for 1960s dodge, or ford 4x4 or bobbed duce)
Please call, text or e mail any questions.
Regards,
Christian
cdelcollo@gmail.com
215.510.8007
