Old 10-22-2012, 03:27 PM
Default Foaming gunnels
Has anyone considered or done this. In redoing my deck on a 20SF, i've noticed there to be some decent flex with my deck removed when i push on the interior gunnels. i realize that replacing the deck will firm this up once i reglass it to the sides but would there be any benefit in pouring foam through various holes (rod holders, etc...) to fill up the emptiness between the inner and outer liner of the hull? Would this help making the deck more solid too since everything would then be connected, all be it with foam in the gunnels.
Or is it an invitation for water to enter through all the holes typically placed on the top cap and to trap water there?
Old 10-24-2012, 08:01 PM
Billpotter Billpotter is offline
It is an invitation for water to enter through at any opening; rod hon
Oder, loosened rub rail fastening or hull deck joint- I wouldn't do it-
Good luck
Bill Potter
18' 1978, Yamaha 130
23' CC 1986, T Suzuki F115s (current full custom project)
Old 10-25-2012, 08:33 AM
Briguy Briguy is offline
Foam is way expensive!
Capt. Brian
