Old 11-03-2012, 10:58 PM
erebus erebus is offline
Default 18SF tank size
Just yanked my tank out today and was surprised to find that it was only two thirds the size it could have been.
Did SeaCraft have any particular reason for this in the 18 footers?
Would it be detrimental for me to have a tank made to accommodate the entire space? I imagine I could pick up some range that way, but also some weight.
It is down low though.
Anyone out there who's rehabbed an 18 want to weigh in?
Zachary
Old 11-03-2012, 11:03 PM
And does anybody have a favorite tank manufacturer here in the North East?
I know I could get one shipped from Florida pretty easy (Sunshine, RDS, Florida Marine) but anybody recommended up here in the Cape Cod vicinity?
I think New England Propeller builds tanks but I have no direct experience with them.
Just looking for opinions.
Zachary
Old 11-03-2012, 11:17 PM
I used Sunshine and very satisfied
Old 11-04-2012, 08:20 AM
I would highly recommend Eric Kent at KentFab; I believe they are now in Pembroke, MA.
Very high quality work and a nice guy to do business with on top of that. Good luck with the project.
Old 11-04-2012, 09:38 AM
GodsReel GodsReel is offline
If you plan to go with new motor technology ,you won't need extra capacity. I would use it for storage,or move tank forward to counter the added weight of 4 stroke or maybe a bracket if you are thinking of going that way with it. Food for thought.
Old 11-04-2012, 01:59 PM
I bought a plastic tank at a place in Portmouth RI, I can't think of the name offhand but someone else may chime in.They had many sizes to choose from.
P.S. I will be calling you soon to set up a time to get the footrest to you.I will probably be in Chatham next sunday.
Old 11-04-2012, 03:17 PM
sidelock sidelock is offline
I bought a 1975 18 SF in the spring & had it shipped from Louisiana to the North East. The boat is in unbelivable shape & there is no soft spots or cracks anywhere. The two brothers I bought if from took very good care of it & they kept things very simple , no unnecessary holes to deal with. Anyhow, they replaced the fuel tank with a plastic one & they provided me with pictures of the install.
Its a 40 gallon tank made by MOLLER , fits just right in the coffin box of the 18 SF & measures 60"L x 23" W x 7.78 " H in the middle & tapers out to 6.87" H on the ends. Part # FT4032 . The top of the tank is flat & the bottom is chamfered or beveled @ the sides. There is an 8" flat section on the bottom of the tank in the middle where it measures 7.87" high & the ends or sides that are beveled on the bottom & measure 6.87" high are 7'5" wide on both sides.
Hope that helps.
Old 11-04-2012, 09:12 PM
Pasqueisle Pasqueisle is offline
I have a 77sf18 that I'm gradually restoring. I did the fuel tank 2 yrs. ago and found the same undersized tank that you did. I looked locally for a fabricator on cape, but settled on Speedy Tanks in NJ. I gave them the measurements and they had a custom built aluminum tank on my doorstep in about a week. I don't recall the exact dimensions, but I think I went from 35 gallons to 43. Because the extra capacity is forward it should improve your COG I believe, at least when full. I do agree with Sidelock's comment however, that you probably don't need a lot more range on an inshore boat with efficient power.
Old 11-04-2012, 09:42 PM
You should have had a 30 gal tank when she left the plant in Miami. THE 80'S 18SF's were 47 gals originally. Im not sure about the space being bigger than the tank in a Potter 18.
Old 11-05-2012, 05:21 PM
Danny my '78 I'm pretty sure had a 47, may have been an option
