Old 12-13-2012, 06:15 PM
bgreene bgreene is offline
Default Does the Sceptre dig in the bow with single outboard ?
One guy advised me the Sceptre with single outboard rides lower in the bow than stern at " displacement speeds " and steering therefore wanders - doesn't track straight.
Is this a common issue ?
Old 12-13-2012, 06:20 PM
No
Old 12-13-2012, 07:36 PM
BigLew BigLew is offline
What he was probably referring to I what I have been told and observed is the "Deep V wiggle."
It is a tendency of virtually all Deep V's to be very sensitive to surface conditions, wind and currents at hull speed and lower. This is because, I've been told, it is essentially due to dynamic responsiveness of the design that at higher/planing speeds is an desirable attribute of its tacking ability. The Seacraft hulls maybe SLIGHTLY more prone to it only because of their exceptional tracking ability at planing speeds.
Plan accordingly!
Old 12-13-2012, 09:49 PM
Always get a tracking number. Light is right. Balance is Paramount. Tracking comes down to hydraulics or Dinosaurs like me. Look forward. Adjust the wheel as necessary. Be safe.
Cheers,
GFS
Old 12-13-2012, 10:18 PM
That's pretty common, but only when you are sucking down a margarita in a no wake zone, staring at chicks in bikini's, or when you can't pull your head out of the fish finder/gps to pay attention and see where you are driving.
Old 12-14-2012, 09:22 AM
all deep v's, regardless of power configuration, tend to do this at less than hull speed.
I like the way Tim describes it, though....
Old 12-14-2012, 01:08 PM
76Red18 76Red18 is offline
The Mirage plus prop I tried made my 18 cc wander around at lower speeds. He might have had a prop issue.
J. M. Hendrix
Old 12-14-2012, 03:05 PM
cdavisdb cdavisdb is offline
I guess the perception of "wandering" is influenced by what you are used to, in my case, deepVs, but my Seafari is a whole lot deeper than a Sceptre, probably 600 lbs+ lighter in the stern than it was designed for and, if it wanders, I sure don't notice. For sure, if "wandering" was an issue, mine should be much worse than an outboard Septre.
Old 12-14-2012, 09:00 PM
Upon re-reading Tim's reply, I like his better. too! I'm torn between the margarita's and the BIKINI'd though!
Plan accordingly!
Old 12-14-2012, 10:31 PM
I should probably add that twin thrust vector eliminates 90% of the wander; with twins, pretty much all that is left is often margarita-induced......
