Old 12-21-2012, 06:54 PM
Default oil tank placement
right now I premix the oil in the fuel tank as the oil pump dosent work. were the oil tank was I built a small bait tank under the stern hatch,
the floor bait tank id like to seal off and install a water tight hatch lid. if I ever install a new motor id like to install the oil tank in the old bait tank under the floor ,. is there any reason this wouldn't work?being too low?
82 seacraft 20SF
Bayview Canvas
Old 12-21-2012, 06:59 PM
they are usually 3 gal, not sure its big enough, on my MA its on the old battery platform in the port transom but I have more room back there I know.
Old 12-21-2012, 07:52 PM
the tank I removed I still have and fit in that 9" or so wide hatch it will fit below im sure as I measured it before when I was thiking of it . it not 3 gall maybe 1 I did remove some oil from it about a gallon id use it if I could im just wondering it there a high issue for getting the oil up to the motor id think it would pump up ok
82 seacraft 20SF
Bayview Canvas
Old 12-21-2012, 08:03 PM
shana shana is offline
stay with the pre mix cant go wrong that way works great for me no more smokin
george j victor jr
Old 12-21-2012, 11:10 PM
ct9amr ct9amr is offline
The oil take for my contender is in the bilge area and has been fine.
Definitely lower than the engine.
Glen
Old 12-22-2012, 08:35 AM
The Yamaha tanks have a carbon steel "mount" that rusts easily. There are SS available though. They also have a small, inline filter close to the bottom that's easy to change but needs to be accessible. I had one clog once and manually refilled the engine tank to get home
Old 12-22-2012, 10:37 AM
Where do you get the stainless oil tank mount? The one in the bilge my 23 contender is rusting. Also ive never seen the oil tank filter. Where is it?
Old 12-22-2012, 11:20 AM
Lordwrench Lordwrench is offline
My merc 150 is spec'd with 1.5 gallon tank and works perfectly. It's a positive pressure system,height is irrelevant.
Old 12-22-2012, 02:31 PM
Yamaha #646-24251-02-00 strainer. #21 You'll have to search THT for the SS tank strap. Yamaha wants $150 for theirs.
http://yamahamc.partsandwarranty.com...=939040&Page=1
Old 12-23-2012, 10:11 PM
I found a place that makes the stainless tank mount for 119. How often should that oil tank filter be changed?
