Old 12-26-2012, 05:29 PM
lawrence s lawrence s is offline
Default scupper tube replacement
how do replace the brass tubes in the scupper drains on my 76 septer
Old 12-27-2012, 02:53 AM
Click here: http://www.wholesalemarine.com/pc/S-...+520290-1.html
Remove the old ones. A socket, hammer and chisel are your friends. You will need at least 5 beers and 3 cigars (if you smoke) to complete this job. After the old ones are removed you need to clean the hole out real good with a round file or what ever will work. Some of the hardwares stores carry a circular wire brush that mounts to a standard drill and that will help to remove any old calking thats in the hole. After you get the big stuff out clean the hole with acetone. Next cut the tubes the right length using a pipe cutter. Swab the hole and the tube with lots of 5200 and use flaring tool to seat the new brass tube in place. Buy a couple extra brass tubes just in case you screw up one. Good luck!
One more thing...I will caution you that the brass tube is mounted in a wooden block between the deck and bottom of the hull. This wooden block must be sound (not rotton) to support the brass tubes. If it is rotton it will need to be replaced. Another option is to route the scuppers out the back of the boat which is what a lot of us tend to do anyways.
Old 12-27-2012, 09:59 AM
Bryan A. Bryan A. is offline
Thumbs up
The Obi Wan of SeaCraft repair has spoken.
It doesn't get much better than that!!!
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 12-27-2012, 09:03 PM
hermco hermco is offline
5 beers?
Old 12-27-2012, 09:13 PM
8 if you dont smoke
1974 23SF
Old 12-28-2012, 12:47 AM
Ok I was wrong it will take a 12 pack and at least 5 cigars
Old 12-28-2012, 04:36 PM
where would you find that flairing tool
Old 12-28-2012, 04:53 PM
Jamestown distributors has them,thay are about 45$
Old 12-28-2012, 07:03 PM
I get a lot of stuff from CLR Marine.
Price and service have been excellent and Capt Chuck is a nice guy.
http://www.clrmarine.com/m4/MOE%2002...-drain-tu.html
Old 12-28-2012, 11:55 PM
. . . One more thing...I will caution you that the brass tube is mounted in a wooden block between the deck and bottom of the hull. This wooden block must be sound (not rotton) to support the brass tubes. If it is rotton it will need to be replaced. Another option is to route the scuppers out the back of the boat which is what a lot of us tend to do anyways.
The wood block was rotten on one side of my boat. I was able to fill the hole and surrounding space where the rotted wood was by plugging hole from bottom with a PVC plug, filling it with thickened epoxy and then redrilling the hole. Details and pictures are in page 2 of this thread: http://www.classicseacraft.com/commu...cuppers&page=2, starting with post #13. Pics are on page 3, post #29. I was able to make my own flaring tool using a threaded rod, nuts, washers and a 1/2" drive socket that had just the right flare on it!
