Old 02-06-2013, 05:24 PM
hugo hugo is offline
Default Wd-40
i have heard that WD-40 is not the best to spray on a power head because it damages electrical wires. is their any truth to this? what do you all put on your engines to protect your engines? i have a freind that uses corrosion X in the green can but i dont like it because it dries to a thick greasy film then working on the engine for anything realy sucks!
Old 02-06-2013, 05:25 PM
wasent sure if this should be in performance section sorry.
Old 02-06-2013, 05:29 PM
pelican pelican is offline
very true !!
CRC 656
lear research - "corrosion block" spray
these 2 products are the only 2 i'm aware of,that actually neutralize salt/corrosion
http://learchem.com/products/corrosion-block.html
i use corosion block on client's boats - along with my own,best product available...
DO NOT confuse "corrosion block" with that waxy useless crap - not the same product !
Old 02-06-2013, 05:34 PM
thanks pelican, does it dry greasy?
Old 02-06-2013, 05:41 PM
nope
Old 02-06-2013, 05:59 PM
done deal! thanks
west marine has some in stock down the street.
