Old 03-21-2013, 09:48 PM
Default 85 HP Johnson
I picked up a lappy project boat last month and finally had time
to clean the carbs and check the motor out that came with the boat.
It is a 1975 Johnson with a 20 inch shaft and no TNT....
After soaking the carbs and reinstalling, I checked the compression which comes in at 128lbs. on all four cyclinders... There was a a bad ground
on the number one coil of which I fixed as well..
Has 4 new plugs to boot.
Make a long story short this ole' girl runs like a top!!!
It could use a new impeller and a gear lube change to make it right..
It comes with the control box, cables, (not the best, but work)
SST prop, looks to be 13 X 19 not sure though....
I have this listed on CL for 500 clams!
Family price on CSC $300
It starts right up and runs great!
Currently mounted on a roll around stand for demo purposes.
I have had a couple of tire kicker calls...
Hey, it is what it is! Oldie but goodie..
Come and get it at Area 442..
Name:  Johnson 85 HP 001.jpg
Name:  Johnson 85 HP 002.jpg
Name:  Johnson 85 HP 003.jpg
Name:  Johnson 85 HP 004.jpg
Name:  Johnson 85 HP 005.jpg
Name:  Johnson 85 HP 006.jpg
Name:  Johnson 85 HP 007.jpg
Name:  Johnson 85 HP 008.jpg
Old 03-21-2013, 09:55 PM
I had that same engine on a 16 Checkmate that we had on my lake and we used it 300 days out of the year and must have put 3000 hrs on it before I traded it in for a 150 and I put another million hours on that one. All my childhood friends learned how to ski behind my house They even gave the lake a name ...skinny lake as my nick name was in spanish el flaco ( skinny to you anglos) Great engine !!!
Old 03-21-2013, 10:16 PM
We had a 1971 115hp (v-4) Evinrude on a 19' Cobia back in the day. I learned to handle a boat with that little ride. The V-4 OMCs were great engines.
GLWS, someone should snap it up at $300!
Old 03-22-2013, 08:47 PM
riverrat riverrat is offline
Does it include free shipping.......
Old 03-23-2013, 07:08 AM
As if you needed another project.
Old 03-23-2013, 08:54 PM
While that is a thought, I spread dialectric grease around the boat.
