Old 04-07-2013, 09:19 AM
OilFieldMan OilFieldMan is offline
Default 1974 20' CC Seacraft for sale
This is a hull from the 70's that is completely un-molested with holes and extra crap.
The fuel, bait, fish box, anchor, and seat hatches were all re-cored last in 2011.
The bow rail is unbent and still has good luster.
The gel coat is in good shape no major dings or scratches. It is the original gel coat to my knowledge. However with a good buff and a seasonal coating of poly glow she looks like a million bucks.
Fuel tank appears to be original however this was installed with out foam around it. No pitting or corrosion apparent, no leaks, can not smell fuel in the bilge.
1985 Evinrude 150 Hp 2 stroke
-2011 installed new fuel pump (capped of oil injection and run premix)
-New fuel lines
-Carbs cleaned last season
-Baystar hydraulic steering (also have the updated tiller arm for a Etec when it gets repowered)
-New Trans/throttle cables
-Compression is even across all cylinders.
Now the goodies and extras on the boat
-750 gph rule bilge pump on a float switch and manual operation
-1600 gph johnson bilge pump manual switch
-larger t-top that has not been fitted to the boat
-rl70c pathfinder plus and the other is a L760 plus fish finder, GPS and radar
-installed in 2011 Standard UHF radio
-installed 2012 pyle radio and speakers installed on the console
The boat sits on a 2011 Venture bunk trailer.
I work in maintenance this boat has been regularly washed when taken out of the water, and the trailer bearings been greased and trailer washed as well. The boat is currently winterized and upon seeing some money I am more than willing to take a test ride.
7,500
I've worked all the kinks out of the boat it truely is turn key. The 23 Scepter in the pictures is the new Seacraft that has replaced this gem.
Unique Transaction ID # 2AF17197XF499724L
1974 Seacraft 20' SF with 1985 Evinrude 150 VRO
1987 Seacraft 23' Scepter with 2007 250 HP Evinrude Etec
