Old 04-14-2013, 02:21 PM
Default Splash day
With my terrible prop, 20 gallons of fuel and 3 people. Plane speed was 12-14 knots, top speed was 28, cruise around 20 I guess. Any prop suggestions for this setup. Mine is a 17p. Here are some shots
Old 04-14-2013, 06:33 PM
Congrats Chance!
Looks like you got your extension figured out. That Bigshrimpin fellow is pretty bright, huh?
What prop are you running now?
Are you coming in a bit under the desired max rpms at WOT.
If so, I think the 15p black max prop would help you some on the hole shot and get the stern up. She looks look pretty balanced though.
I'm running a 115 inline 6 and getting 36mph at 5600rpm on a Seafari with said prop. If you want stainless, Powertech Makes the MQF3 series. Same design. Moderate rake low cup easy-to-turn big blades. Did wonders for my motor and overall performance. I believe the stilletto is very similar and has a bit of a following, too. Just not sure if the 115 turns it as easily.
Hope you find the solution. I concur, 28mph is not satisfactory on a 20 w/ a 115.
p.s. is the green stuff on the hull, botanical growth, or just paint? Just a ? of friction.
Old 04-14-2013, 06:42 PM
That's not as terrible as you think (to me, with a lower power 4 stroke). I get those numbers with a yamaha F100 on a 20 master angler with a 13" x 15" pitch 4 blade and a hydroshield. Probably similar prop RPM, higher engine RPM, as I have a 2.31 gearcase. I think a 15" pitch might be better- maybe with a bit of cup added, maybe not. With a 4 blade and less pitch, hole shot will be good, as will low speed planing, which is nice for the rougher stuff in a 20. They say a 3 blade will give a bit more speed. I never tried-I rarely get to use 28 knots in Buzzards Bay. I run almost the same top speed, just 1-2MPH slower with a 17P prop, but much lower RPM and crappy holeshot.
I don't know RPMs for that engine, but I bet you are a bit low.
If you want to go faster, I wouldn't suggest a hydroshield with it's drag, but it does seem to keep a heavy 4 stroke and kicker on plane better (like mine). You don't have that problem with a light 115 2 stroke. The normal fins on top of the anti ventilation plate will help you get it up on plane faster, if you don't have one.
Nice looking boat!
Old 04-14-2013, 06:56 PM
Thanks, this probably has something to do with part of my numbers
This picture is of the only numbers on the prop. The 17P is self explanatory, but I don't know the diameter or what the rest of these numbers mean
What diameter was your 15p you were running? The bottom is a combo of some minimal growth and a few layers of old bottom paint. I didn't touch the hull, ran out of money.
That bigshrimpin guys is pretty bright. I'm not sure exactly what I got for RPMs I'll have to pay attention to that next time. I was only out for about 15 minutes today during the only rain shower of the day.
I don't really know if I care about whole shot more than getting more cruising speed. So it sounds like a 3 blade 15 pitch, but what diameter? 13?? Thanks for they help guys
Old 04-14-2013, 07:24 PM
I run a 13" diameter 15" pitch Solas Amita4 aluminum prop. $110 from boats.net. I started with the 17" pitch version which is 12-3/4" diameter. Same splines and hub diameter as your Merc, I bet.
There is a stainless 16" pitch Yamaha 4 blade that should fit- but it is probably near $300 used, and $450 new? And there re probably many others.
The local prop shop doesn't like the Solas props- (I think) there is no profit margin. I like it for that reason.
The prop manufacturer I worked with at my last job (ACME- they make fully CNC machined bronze inboard props) said it is easier for a prop shop to take cup out of a prop accurately than put it in. I am not sure if that applies to small outboard props.
http://www.classicseacraft.com/commu...ad.php?t=24872
I condensed my prop experience in the thread above.
I have photobucket pics here of my prop and hydroshield. The motor was a hole or two too low- I raised it after these pics were taken. The flying wing helps lift the extra 150 lb on the transom. Along with an under console fuel tank and battery setup.
http://s1119.photobucket.com/user/Fi...tml?sort=3&o=0
Originally Posted by CHANCE1234 View Post
Thanks, this probably has something to do with part of my numbers<snip>
Old 04-14-2013, 07:47 PM
Yeah, that prop is the right one but the wrong shape - it should have more curves... You have the Mercury Black Max there.
The 15p has a 13-3/4" diameter. Quicksilver model is called Black Diamond, QA2034X is 15p model no. 17p has 13-1/4" diameter, model no. is QA2036X. Should be same sizes for Mercury Black Max.
You will do much better with a new prop. Any shop should have this prop used, in good shape. Try them both pitches with a "heavy" load. If regularly run with 3 people, I'd stick w/ the 15 pitch.
When you run them monitor your rpms. You should be able to achieve the maximum targeted rpms for your motor at WOT.
Good luck! Keep us posted on your performance results.
Old 04-14-2013, 07:48 PM
Fastest restore yet! Congrats on being back in a seacraft
Old 04-14-2013, 09:25 PM
Thanks guys, I'll be on the lookout for a 13x15 prop and give that a shot. I doubt it will happen before I go to California for 5 weeks but definitely as soon as I get back. I leave Sunday and am now officially broke.
Strick, fast maybe...solid, yes...perfect, nope...but it's mine and I did it. I love the pictures my wife took. Can't wait to come back from Cali and fish it.
Old 04-14-2013, 10:04 PM
Congrats! Great to see you on the water!
Gillie has some great advise there, so don't worry about your performance numbers until you get a clean prop on her.
Catch 'em up when you get back from Cali
Lloyd
Old 04-16-2013, 12:05 AM
Nice Chance! Just got mine wet yesterday, will post a few photos up.
