Old 04-23-2013, 11:53 AM
Question Another Prop Question
Currently running a 14 1/2 inch x 15 pitch prop on 175 Etec- get about 5400 rmp's top end. The prop is a no-name aftermarket stainless steel and the blades have little to no sweep to them. Thinking about going to a Evinrude Rebel prop 15 3/4 inch by 15 pitch with pronounced swept blades. Have heard varied guesses on what performance will be gained or lost. Before I spring for $400 would like to hear some opinions- thanks!
Old 04-23-2013, 01:31 PM
ct9amr ct9amr is offline
Post up on propgods.
Ken will probably have a good answer for you.
http://www.propgods.com/
He was right on the money for my Contender.
Glen
Old 04-23-2013, 02:33 PM
The OPTIMUM rpm range on the small-block V-6 E-TEC is 5300-5500 for the 2007 models like mine, but it's 5500-5600 for all later models per this web site: http://www.etecownersgroup.com/post/...u-2011-5396435 Your WOT rpm may be a couple hundred rpm too low depending on what year your motor is. Before you change props, make sure motor is mounted high enough that you can clearly see the AV plate out of the water when you're up on plane. And of course make sure the tach is accurate (not a problem if using I-Command!)
I've heard good things about cruise and min planing speed performance of the Rebel prop and asked my dealer about it. He said his experience was that it was better suited to the big block 3.3/3.4L motors, especially on a heavy boat. He didn't think the 2.6L motors had the torque to spin it fast enough unless they were on a boat much lighter than mine, and I think your boat is a fair bit heavier. I'm running a 4B 15 x15 PowerTech prop that uses the old SST blade profile and spins 5450 pretty much regardless of load at about 39-40 mph. I'm giving up several mph in top end, but it has an awesome hole shot, stays on plane down to 12 mph, and has averaged over 4 mpg on trips of 250-700 miles. I'd like to try a Rebel sometime, but I'm not sure I can improve on that performance very much! If you're able try one, let me know how it works out! Denny
Old 04-23-2013, 06:09 PM
Denny.....please take it easy! You keep bringing up the 4 mpg, which you darn sure should be quite proud of, so just to let you know us 2 mpg guys are really jealous!! Seeya Friday!!
Old 04-24-2013, 01:18 PM
Commander Coo1 Commander Coo1 is offline
I am not a Sea Craft owner, just an admirer and reader. My 20' Whaler Outrage does well with a 15p Enertia on a 175 E-TEC. I found the Rebel 15p held my rpm down too much. What kind of speed do you get at cruise and WOT? Ken from propgods.com really helped me out!
Old 04-25-2013, 08:55 AM
Default Props
Yes, I have been talking to Ken- very helpful for sure. Wide open is 30/31 kts. and cruise is 24
Old 04-25-2013, 11:58 AM
looks like you have about 15% slip at WOT which seems pretty high. The Enertia got me about 2% slip and the Rebel was "0%". you may end up needing to come down in pitch unless you pick up a decent amount of speed. My setup weighs about 4000lbs loaded and tops out at about 43mph/37kts.
Old 04-25-2013, 02:54 PM
I can't imagine a 175 Etec on what looks like a 20 not being able to swing a 15 anything? Frankly I'm not sure it can be a 15, a 150 OMC on a 20 swings a 17 and I run a 19 with only 25HP, just seems odd unless its a 23.
Old 04-25-2013, 06:27 PM
Egg I think I read you have a 200 merc on your 20 what size prop do you have?
I just got a 2001 with no prop.
82 seacraft 20SF
Bayview Canvas
Old 04-25-2013, 07:21 PM
Jeeeez Dog...a 15 pitch, of any brand, on a 20'er with 150 plus HP ought to spin the engine to it's max...and then some!!!!
