I have a thread under general, but seeing as I keep posting rehab/modification progress, I figured I would post it here.
I finally named the boat- "Bass Relief". I think the dinghy will be named "Art Minor". Unless I do build the collapsible dinghy for transom mount- that will be called "Packed Launch". ![]() I have been filling a jillion screw holes in the deck so that rain water doesn't further damage any balsa core deck. Like I mentioned elsewhere- these got either JB Weld "Water Putty" epoxy putty, or the runnier PC-11 putty. Then a layer of duratec vinylester primer- it is a bit old, from last year, but it kicked fine. I think it freezes well during winter. ![]() Apart from slight discoloration, the putties cover well. The PC11 discolored, the JB Weld didn't. But it is too firm to be worked into smaller places. Here is a before and halfway- at the first layer of vinylester primer stage. I filled the ~2" hole with water putty and belt sanded flush. The corner drains are ~3/4" diameter. They will get drip tray to drain toward the keel, I think. But that hasn't been implemented yet. I used polyester body filler for the holes in the cabin roof, and gel coated that straight away. Once I wash the last of the PVA off, I will take pictures. I just ordered a gallon of VE resin and some divinycell- there are a few hatches that need looking after. My trim tabs are mounted funny, across the outer and 2nd from outer steps in teh hull, so making a set of extensions might be in my future. Plus a (maybe convertible) hard top made of nidacore/glass/VE is planned. Or maybe the old basket weave carbon I have. I can't use it under water- it will corrode everything else, and wick water into the structure. Last edited by FishStretcher; 05-07-2013 at 10:58 PM. |
