Old 05-19-2013, 11:17 AM
newellchunker newellchunker is offline
Default Garage Clean Out
Time to thin some stuff:
(1) Set of Bennett Trim Tabs that are in good working condition that was on a project boat, the only thing you will need is the wiring harness from the switch to the HPU (can very easily be made up) asking $300.00 shipped.
(2) An Icom IC-M2A handheld that the antenna cracked on it and was replaced by a "stubby" antenna and then the battery pack went out. I tried to replace the Ni-Cads and ended up throwing the battery pack away, has an AC charger, it just needs a BP223 or BP224 battery pack, $25.00 shipped.
(3) I've also got a Penn 6/0 mated with an Electramate 612 that was just loaded with Ande 50lb mono and it needs your plug....works perfectly with a Daiwa Sealine rod, $400.00 shipped.
(4) I also have a Penn 6/0 loaded with fresh Ande 50lb mono on a custom wrapped rod asking $150.00 prefer local pick-up due to rod length.
(5)**SOLD** Pair of Lee's 9in 30 degree rodholders asking $65.00 shipped. **SOLD** Thanks Chance1234!!
Here's a link with pics: http://www.thehulltruth.com/parts-fo...clean-out.html
Keith Willis 25ft Downeaster Pilothouse
Ford F350 Super Duty SRW
1977 SeaCraft Sceptre- SOLD
