Old 09-08-2013, 04:38 PM
bilgerat bilgerat is offline
Default My 73 20' project
well got started on the tear down this weekend, got her disassembled and ready to pull the cap, every thing came apart fairly easy ill I got to the fuel tank, then I found the Potter foam!!!
I got My fiberglass guy coming over tomorrow to give her a look and some ideas on what is to come.
I know he time to start spending $ is in My near future!!!
Old 09-08-2013, 04:44 PM
PharmD2B31 PharmD2B31 is offline
Good luck with your '73...... I am hoping to get some more tore down on my '73 also this next week.
Old 09-08-2013, 10:55 PM
Foam helps hold water against the tank to cause the equivalent of crevice corrosion, so might as well plan on replacing that tank! Use a pressure washer to blow away all that foam and remove the tank! And DON'T foam in the new tank!
Old 09-09-2013, 05:23 PM
ran into that with my 25, tanks were shot, had to have new tanks custom built for it.
ill go back with a poly tank on this one
I did get the console stripped down today, is in kinda rough shape, gonna take some work to fix all the cracks in it .
Old 02-09-2014, 07:10 PM
Ok, been a while since I posted anything, put the 20 on the back burner for a while,{deer season in Ga is 4 months long } back on it for a few hours here and there this past few weeks,got the rear deck cut out and the rotten transom removed , then I finished cutting the floor out and got the deck separated from the hull , I dug the foam out around the fuel tank and got it lifted up and our of the hole, now on to clean up and getting all the foam removed, any tips on the best way to accomplish this?
Old 02-09-2014, 07:11 PM
few more with the transom bout removed
Old 02-17-2014, 07:29 PM
deck off , all rotten wood removed, tank and foam removed, almost time to start construction instead of destruction!!!!
Im trying to do this with out removing the front liner, anyone else done it this way?
Old 02-17-2014, 08:31 PM
You asked about getting the foam out. Well, for getting every last bit, I would suggest:
I would pull the tank deck/floor, then pressure wash. Then pressure wash with soap, like simple green to degrease. Then pressure wash with clean water. Then grit blast anywhere you want to glass or paint, then pressure wash with clean water again. Then you are cleaned, and you don't need to sand.
Old 02-18-2014, 11:16 PM
sjef sjef is offline
How about the foam in the stringers, mine was saturated with water. I ended up cutting the tops off of the stringers and removing all of the foam. It was a real mess but I just couldn't see leaving wet foam in there.
Old 02-19-2014, 11:25 AM
the foam in the stringers is dry, I stuck My moisture meter I use for My house plants into it and it came up dry!. the foam around the gas tank was the only foam that was wet
