Old 10-30-2013, 10:00 PM
Default 84 23' Center console tank size
More than likely going to replace the 144 gallon tank in the 23 with a smaller around 80 to 90 gallon tank. Anyone know offhand what the width and depth of the fuel compartment is. Got a good lead on a 90 gallon Inca. Going to raise the floor 3 to 4 inches so can get some height there.
Old 11-18-2013, 04:57 PM
Seacraft 84-we are in the midst of replacing ours with a tank from Sunshine tanks in FL. We have a 23 that is one year newer than yours. The box it sits in beneath the floor is 29" wide by 14" deep-the enclosure is open to the bow, enclosed on 3 sides. I added drains with little pvc fittings so that water will flow into the bilge. Our tank will be a little over 100 gallons. Good luck with your project. We had to cut ours out in pieces with a metal/aluminum cutting tool called a nibbler. No more foam-we are using 5200 and strips of starboard.
Old 11-18-2013, 09:49 PM
Thanks. The existing tank looks in good shape but don't need to haul all the extra gas around.
Be aware that 5200 doesn't adhere too good to starboard.
I used strips of fiberglass I cut from used pieces from demoing a fiberglass boat.
I'm assuming you are using the strips to hold the tank up so air can circulate around the tank?
That is the David Pascoes method of installing aluminum tanks.
Bare aluminum, no coating necessary.
LOL. Just saw your post on fuel tank.
Old 11-18-2013, 10:31 PM
X2 on the starboard 5200 combo.
Old 11-18-2013, 11:13 PM
Billpotter Billpotter is offline
FYI- If you raise the weather deck (floor) more than 2.5", don't say I didn't warn you. I have raised the deck on my 1986 23' project 2.5" by raising the whole liner up- liner flare begins to pull away from the hull beyond 2.5"- difficult to re-join the two- but possible. Also, gunwale height is about 25" aft at that point: getting close to stumbling overboard.
Regarding reducing tank size, fuel weight placement is key. If you have one tank that goes forward from the aft between stringer bulkhead, fuel weight will still be aft when you are underway above idle. Consider two tanks to better control weight placement. This will also maximize resale value.
Bill Potter
18' 1978, Yamaha 130
23' CC 1986, T Suzuki F115s (current full custom project)
Old 11-18-2013, 11:20 PM
Thanks Bill.
Plan is to completely remove the inner liner and deck and go with a level deck so we can move the tank even farther forward to keep the weight from being aft. These 4 strokes get such good mileage I can't see going with anything over 90 gallons. As you know these boats were built back when motors only got 1 to 1/2 mpg.
Old 11-19-2013, 11:03 PM
Understood-
On my current project (23 CC, twin suzuki DF115s on the transom- 850 lbs. approx.), I ended up splitting 120 gallons into a forward 50 in front of a console step in, and an aft 70 behind the console step in, behind which is a forward of transom storage area that's long enough to store long diving fins and gear. I also built a 15 ga. oval quick trip live well in the starboard stern because I like fresh fish. With the two tank set up, I can place the fuel where it is best for the circumstances; keeping it well forward when I want to.
Note that before taking the boat apart, I trial ran the boat for 6 hours in conditions up to washing machine 3-4' seas with the Suzuki F115s to verify my plans. The aft rushing fuel weight was obvious.
26 years ago, I set up a 3 tank (195 gallon total) 23 for a friend: it was very handy to be able to change the balance of the boat with different fuel placement for different circumstances.Just make sure you have a good idea as to how she'll sit and run with the different set up.
Keep in mind that as soon as the bow rises, no matter how many baffles there are in the tank, all the fuel goes to the rear of the tank.
Bill Potter
Old 11-23-2013, 11:08 AM
We will be using fiberglass strips instead of starboard-thanks for the headsup.
