Old 11-07-2013, 06:37 AM
fishmore2013 fishmore2013 is offline
Default how to repair lower/upper hull junction{cap}
I started taking a part my 77 20' seacraft-removed the bumper strip and found a lot of drilled holes and the upper(cap) and lower hull separated, looks like someone caulked this before
Can anyone tell me what fill to use for these holes and what caulk to seal this joint?
Thanks Jon
Old 11-07-2013, 07:56 PM
MPMag MPMag is offline
Had this to deal with back in the day. Used Marinetech 2 part material since the bond has to stay secure but didn't need to be cosmetic. Seemed like a good solution.
Old 11-09-2013, 10:53 AM
dandub20 dandub20 is offline
Mine had a ton of holes! I pulled the cap off and putty all the holes then glassed over them
Old 11-12-2013, 06:39 PM
Default cap advice thanks
thanks for the advice guys
Jon
Old 11-12-2013, 08:51 PM
parrott parrott is offline
Epoxy and cabosil to fill holes then 5200 between hull and cap. Thru bolt instead of screws or rivets
Old 11-12-2013, 09:01 PM
Or Sikaflex for the glue. Takeapartable is nice.
Do you bolt a motah together or weld it?
Yeah, I`m a bit twisted.
