Old 11-18-2013, 09:13 PM
verch verch is offline
Default Rod Holder simple fix
I just purchased a 89' 20' seacraft and one of the first things I noticed is that the bottom bracket on both rod holders was broken. I had to make a trip to Lowes for some zip ties and while in the electrical dept. I noticed these cool little Bungee's made for strapping wires back. After straightening up the wood and cutting a bungee slot with a coping saw they fit perfectly. Best part is I got a pack of 10 of them for $7.
Old 11-19-2013, 09:26 AM
Rufneck Rufneck is offline
That is a good idea and something I need to do as well. The bunge cords on my rod holders were pretty worn out so I cut them out. Could you not have run the new bungees through the hole that the original bungees were routed? Why the need for the black plastic piece. I would have thought that you could have cut the bungee, run it through the hole and then used some type of crimp to connect it back together.
Old 11-19-2013, 08:49 PM
That would have been a great option if the bottom of the bracket where the bungee fastens in the wood slot wasn't broken off. This was easier than cutting new rod holders out of wood.
