Old 11-30-2013, 02:07 PM
jesse@tsiaviation.com jesse@tsiaviation.com is offline
Default 150 Merc' Help
I have a new to me 150 Mercury 2001' motor, when the motor is in nutral it's revving at 1200 rpm's (on the hose) and makes a crackling sound when going into gear.
Any suggestions?
Old 11-30-2013, 06:51 PM
conchcuzzy conchcuzzy is offline
Is this an optimax? Perhaps a previous owner set the throttle advance screw a little too far. Sometimes this is done to compensate for the tough cold start these motors are known for. In fact I believe they are supposed to idle at about 1,200 until the engine temp reaches 145 degrees.
HTH
Old 11-30-2013, 07:43 PM
Two Links:
Service manual
http://boatinfo.no/lib/mercury/manua...00-225.html#/0
everything you ever wanted to know about merc v6 2.5L engines.
www.screamandfly.com
Old 11-30-2013, 07:44 PM
Crackling or grinding when shifting?
What is RPM when in gear at idle . . . not on a hose?
sounds like simple cable adjustments.
Old 11-30-2013, 08:17 PM
I'm going to take it to the water tomorrow and see if the RPM's go down once I the motor warms up. If not ill adjust the idle screw.
I just change the impeller a few days ago.
Yes it's a grinding sound.
Thanks for the feedback guys.
Old 11-30-2013, 09:48 PM
RPM in fwd gear at idle should be about 700rpm.
1000 - 1200 is about right at idle in neutral if I remember correctly.
Old 11-30-2013, 11:19 PM
I thought it was making the grinding noise bc it was at 1200 rpm's in nutral. I'm taking it the water in the morning I'll let you know what I find.
Thanks again!
Old 12-01-2013, 12:58 PM
Big shrimp
Took the boat to the water and adjusted the idle screw, brought it down to 800 and she ran fine. Thanks for the help
Old 12-01-2013, 03:41 PM
it will idle higher on the hose
Old 12-01-2013, 03:44 PM
I was still at 1100 rpm's at the ramp today, so I adjusted the idle.
